Smoke Screen
  • mcandmar
    • Apr 2004
    • 5118
    Smoke Screen
    It all started after a hard launch and just after shifting into 2nd the engine had a big stumble, all i could see in the rear view mirror was a wall of smoke. Weird thing is after pulling over and checking it all out it recovered and drove fine again, no visible signs of smoke out the exhaust, it all seemed fine.
    Then this morning i started it up and drove off down the road and it didn’t feel right, smoke trail out the exhaust was visible again and it ran pretty crappy. Came home and had a good poke around again but still can’t put my finger on the problem. Oil pressure and temps havent changed.
    Anybody got any ideas? It seems to run fine after everything has fully warmed up, cold starts seem to exaggerate the problem
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
  • Knight Rider S4
    • 3541
    What was the water level like?
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • quattro
      • Dec 2004
      • 768
      Look at your cambelt has the tensioner pulley started to give way, that sounds like mine last week. if you have asudden big loss of power turn you engine off! i did at 100mph and my engine is ok now!
      Probably the longet S2 project in history EVER!
      • mcandmar
        • Apr 2004
        • 5118
        Waters fine, and from the smell i'm pretty sure its oil burning causing the smoke. Strage thing is its not a constant problem, sometimes it goes away and drives fine.
        A friend suggested i might have broken a piston oil ring. I'm not sure what effect a broken ring would usually have
        • Briggsy
          • Jul 2005
          • 267
          oil breather PCV??
          1995 B4 Audi 80 S2 avant 267bhp and 326lbft *sold*
          2001 P38 Range Rover DHSE 159bhp and 255lbft
          1985 Type85 Audi 90 quattro 135bhp 140lbft
          • valjo
            • 1110
            • Country: Latvia
            Originally posted by Briggsy
            oil breather PCV??
            yes or blocked engine breather lines....
            Audi Coupe S2 1993
            Audi V8 4.2 1993
            Audi cabrio 1998
            • mcandmar
              • Apr 2004
              • 5118
              Had a look around the crank case breather plumbing and it all looks fine, no blockages or leaks. I tried to pull the spark plugs out and have a look but i couldnt get the plug leads off. Upper part is free as i can twist them around a bit, but the part on the plug will not budge
              Seems to be getting better, and once its fully warmed i cant tell the difference. It is using a bit of oil but i'll keep driving it and see what happens.
              • Ghiest RS2
                • Oct 2007
                • 2
                What was the final problem or solution? Having the same thing, and now its progressed to a rough idle and running rich. No pressure leaks, or at least that's what the shop says.
                • mcandmar
                  • Apr 2004
                  • 5118
                  Never did get to the bottom of it, oil usage has gone back to normal but it’s still lumpy on cold starts.
                  I have a theory that’s its something to do with the valve guides. If i drive it very hard and get it fully warmed up, then come back the next day it blows a cloud of white smoke and struggles for the first few seconds. Seems to me like oil is leaking past the guides and sitting in the cyl. For everyday driving its fine, only when i push it hard it does that.
                  Doesn’t explain the first issue, that was like somebody poured a load of oil into the intake manifold, hasent done it since then
                  • 220bhp
                    • 2578
                    • Home: United Kingdom
                    Could be a build up of oil in the turbo pipes or intercooler getting burnt of when you push it hard.
                    • mcandmar
                      • Apr 2004
                      • 5118
                      None turbo mate
