By pass valve orientation and fitment...HELP!
  • AudiCoupeParts
    • Feb 2007
    • 347
    Hi all
    Which end of the bypass valve goes to the Turbo/MAFS hose??? The end with the vacuum line?? Or the opposite?
    I have the ABY/ADU samco set and can't remember how these pieces fit together...
    Thanks to anyone who can help.
    Pictures would be great if you have them!!!
    Regards,
    joe
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    If vacuum on the top, then side goes to turbo hose, and "bottom" to the MAF hose.
    Sau
    • Chris5044
      • Feb 2005
      • 1663
      does this help? .. its not aby but its all i have
        Picture doesn't help unfort...
        The correct orientation is that the vacuum connection is in-line with the hose that connects to the MAF hose. The other connection points down to meet the 25mm take-off hose from the turbo outlet.
        That orients the vacuum hose to point sideways at the chassis which sort of looks wrong but its not !
        Paul
