Problems again!! Need a little help!
  • AudiCoupeParts
    • Feb 2007
    • 347
    Got the engine swapped in and the car running. FINALLY!! Car idles fine, but after a short drive the car seems to drag and slow down. Get home and the damn turbo and pipe is freaking GLOWING RED !!!!
    Car is a 3B that is almost entirely RS2'ed now.
    Big thing I still have NOT received my map ships from my USA Mihnea supplier.
    So, the car is still running stock 3B ECU. Is that why the Turbo glows??
    How many have 3Bs with RS2 Mihnea chips????
    THanks for all who have some knowledge!
    Regards,
    joe
  • mcandmar
    • Apr 2004
    • 5118
    Are you running an RS2 turbo with a stock 3B chip? In that case is going to run very lean, if it were me i would unplug the WGFV to stop it boosting until you get a chip sorted.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • s2dude
      • Nov 2005
      • 1631
      too true!
      way to blow your engine is to keep driving it.
      It will be running way way lean. Either park it up and wait for the chips...or as macandmar says...drive at low rpm off boost.
      If it were me I wouldnt run it again without the correct chips.
      • AudiCoupeParts
        • Feb 2007
        • 347
        Yes, I figured that may have been my problem... I had the FPR vacuum line disconnected by accident and the car ran super rich, but ran fairly well, but not to full potental of course. I then noticed the vacuum line not connected, fixed it and got better milage and less fuel usage. I figured I was good, but then got the glowing red turbo, and horrible exhaust droning noise!!!
        What I have in my car that is RS2....
        RS2...
        Turbo
        IM
        EM
        MAFS
        Airbox
        Fuel rail
        Injectors
        FPR
        IC
        CM
        All of that and a 3B stock ECU just don't mix!!!! :-(
        I had the US Mihnea supply send me a RS2 spec chip set, and it did not work. So he claims to be talking with mihnea to get the correct chips thta do work. I have been waiting a while.
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          RS2...
          Turbo
          IM
          EM
          MAFS
          Airbox
          Fuel rail
          Injectors
          FPR
          IC
          CM
          SS
          • AudiCoupeParts
            • Feb 2007
            • 347
            Thanks 4wheeldrifter for your tease!!! :
            I should have known that I might be playing with if I ran her with all that stuff and no good brains to manage all of it properly.
