MOT Failure :(
  • Azman
    • 3205
    MOT Failure :(
    Hi guys,
    just got back from teh MOT station.
    It Failed - Not on what I thought though!!!!!
    Failed on non working rear licence plate buld one of not both.
    failed on moving ball joint on front drivers side!!! (just got to tighten it up)
    Failed on Front brake lines (just need to cable tie them out of the way of the roll bar they are rubbing on)
    And the biggie!!!!
    All four wheel bearings
    So going to tighten up teh driveshaft bolts to see if that has an effect!! finger crossed as the rest is easy!!
    Funny thing is I have had no noise from the bearings at all.
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • LHD_Kid
    • May 2006
    • 3696
    Originally posted by Azman
    Hi guys,
    And the biggie!!!!
    Sounds a bit suspicious to me Az, all 4 bearings??? I am sure you would have known something if they were fubarred...
    Hope its an easy fix anyway, good luck......
    Chris
    • Azman
      • 3205
      Thats the thing, The fronts have little play, the one rear has a bit more play and the passengers rear has mega play.
      I won't let anyone do an mot without me on their shoulder. (i have learnt the hard way before)
      The good news is with the exhaust etc being done it absolutley blitzed the emmisions test!!!! even with a high 1500rpm idle!!!
      Better get that sorted then!!!
      Dark Grey Avant
      RS2 FARB
        If the driveshafts havent been tightened properly then you might have damaged the bearings already... Worth tryingto tighten them up properly one more time, but if that doesn't do it then its worth knowing that the wheel bearings aren;t expensive in themselves.... Its just the PITA of removing everything to get them changed.
        Paul
        • Azman
          • 3205
          Ar just been looking into that one. would do most of it myself take the legs to someone and have the old one outed and the new ones pressed in.
          fingers crossed just need tightening
          Dark Grey Avant
          RS2 FARB
            Make sure that they are pressed in in the correct order to avoid damaging the bearing, that they are pressed in the correct way round AND that they are pressed in all the way home. I've had a lot of rubbish to sort with wheel bearings not being done correctly. See this thread and go to post 16.
            • Azman
              • 3205
              Ar jason from lion will do it
              Dark Grey Avant
              RS2 FARB
              • Azman
                • 3205
                Right good news and bad!!!
                Sorted it all out (tightened the hub bolts one was a bit loose I must have forgotten to tighten them up fully with the car on the ground)
                Rang them up and manged to get a test this avo!!!
                Here's the kick in the nuts.
                Got down there and the brand new (remember that bit) brake lines for the porsche calipers had split on the passengers side right where the hose meets the union!!!!!
                NOT A HAPPY BUNNY!!!!!!!
                So needless to say a full retest was not done. I have got to get the hose off and get another one made (will be contacting the supplier soon) to sort it all out. Just hope that I can get it all done monday!!!!
                Dark Grey Avant
                RS2 FARB
                • Azman
                  • 3205
                  p.S. the hose wasn't showing signs of leakage at all in the mornings test!!!!!
                  Dark Grey Avant
                  RS2 FARB
                  • Azman
                    • 3205
                    Got to the bottom of the leaking hose today and it was leaking both ends (passengers side only but will have to watch the drivers side now me thinks!!!) The hose ahs not been crimped properly at the ends so it has been seeping from here and eventually gone big style. Will have to get some mad eup in the mean time and speak to those concerned asap!!!
                    Dark Grey Avant
                    RS2 FARB
                      I suggest that you take your car to a mechanic who uses a tool ("Hub Shark") that can extract the wheel bearings from the hub(s) and then press the new one back in all WITHOUT removing the strut or hub from the car. Very quick and efficient IMO.
                      Dave F.
                      • Azman
                        • 3205
                        No probs with the wheel bearings anymore - was just me being a bit dim witted and forgetting to do up the driveshaft bolts
                        Right had a brake line made up today - Three times - just to get one that doesn't leak!!!!!! Strange how they kept on leaking from the same spot.
                        Also shame now I can't get back in for an MOT till tomorow.
                        Dark Grey Avant
                        RS2 FARB
                        • Nj
                          • Jan 2007
                          • 3420
                          • Home: Scotland Current: Finland
                          that's a string of crap you don't need mate. On the plus side you'll be coiled like a frikkin spring so when you have the MOT certificate in hand I fully expect to see you past my way while running it in.
                          1990 CQ20v
                          • Azman
                            • 3205
                            Nah got a reamp to do first
                            Dark Grey Avant
                            RS2 FARB
                            • Azman
                              • 3205
                              Thats remap!!!! Oh and a new amp too
                              Dark Grey Avant
                              RS2 FARB
