Boost gauge tap location suggestions.
  • AudiCoupeParts
    • Feb 2007
    • 347
    I just bought a VDO boost gauge and was wondering if anyone out there could give me a few suggestions as to where I should tap the engine for the gauge tube fitting.
    My line comes through the firewall just to the right and below the heater core (left hand drive car)
    I have various brass NPT fittings so I could go just about anywhere in the engine bay.
    Pictures would be great. I want a clean and easy install and not a lot of hoop-la.
    THanks in advance!
    Joe
  • Dpicariello
    • Mar 2006
    • 621
    Most people tap into the line that goes to the ECU.
    I have recently just renewed all of the fittings as my line was leaking.
    I bought some 3.5mm silicone hose that tightly fits over the existing plastic line. I clamped this up and then put in a 3.5mm T peice that I got from a garden centre!
    I also used the silicone hose to slide over the VDO gauge line.
    All this was then clamped up.
    I got the VDO kit with necessary fittings and olives.
    I don't have any pictures of this though sorry.
    I'm sure there will be someone on here who has posted some pictures of this before so keep searching.
    Dan
    • AudiCoupeParts
      • Feb 2007
      • 347
      Wow! I did not know I could just use the vacuum line for the ECU PT!
      I just need to find another "T" fitting with a proper size nipple for the guage line.
      THanks!
        Been meaning to post this for a while too. Pic of where the line and wires were routed on my install
