Firstly, the turbo will glow after a quick drive, not a problem as long as its not incandescent.. If you pull up quick in the dark and pop the bonnet you can sometimes see the impeller still spinning
Second, do a pressure test for boost leaks
Third, make sure your engine mounts are all good and the xhaust is not sitting on the subframe or touching the floor.
Fit a new pump and filter?
Ok, the glow is very light. Before the remap the turbo looked like the Shankara stones in the Indiana Jones and the Temple of Doom
after a short drive. Now it glows a faint hue of orange.
How do you do a pressure test on these cars????? I am new to turbo power after living for 10 years now with a 7A nonpower Coupe, so I don't know some of the tricks.
Engine mounts and tranny mounts are all new, and the and nothing touches.
I have a new fuel filter.
THe Pump however is just a stock 7A pump wiith the pressure damper. Could that be my problem???
The later Coupes with the 7A engine and 3B and ABys shared the same pumps but WITHOUT a pressure damper on the pump. Could this be the problem??
Thanks for your help!
after a short drive. Now it glows a faint hue of orange.How do you do a pressure test on these cars????? I am new to turbo power after living for 10 years now with a 7A nonpower Coupe, so I don't know some of the tricks.
