Window Regulator
  • neebover
    • May 2005
    • 359
    Window Regulator
    Guys,
    My driver's side electric window will not go up, it is stuck half way down and it is in the garage. I need to know the part number for the window regulator and the best place to buy this part as the main stealer is over £100!!
    Missing her lots!
  • amanda
    Account Disabled
    • Nov 2006
    • 524
    Originally posted by neebover
    Guys,
    Try Pete Reeves at www.quattrocorner.co.uk
    • spink
      • 4382
      Have you checked if there is power getting to the motor?
      • Acidburn
        • 13459
        Other option if you don't want to spend that much is either ebay, audibits or a breakers.
        • amanda
          Account Disabled
          • Nov 2006
          • 524
          Just thinking , have you checked the switch 1st?
          • neebover
            • May 2005
            • 359
            Motor/Switch is fine, window will go down and is currently 3/4 way down but won't go up again! Has anyone got a part number?
            Missing her lots!
            • spink
              • 4382
              Have a look on ebay they sell on there sometimes,or your local breakers although its usually the first part on a coupe that is removed as its a common fault.Ive seen them sell on ebay for upto 100 quid, and 20-40 from a non audi specialist scrapper.It may be possible to butcher a passenger side and use the pulley wheels as i believe its these that wear out,but dont quote me on that.
