MMMMMM Milltek!
  • dest
    • 4287
    MMMMMM Milltek!
    Just had a call from my garage to say its arrived, cant wait till Monday when its fitted
  • Fat Audi 80
    • 10547
    Lucky beggar!
    The Perfectionist
    • Ski
      • 2591
      Im saving my pennies for a 3".. nothing else will improve our performance
      ABY Coupe
      • dest
        • 4287
        We put it on today, and it sounds very nice, but is very boomy too!
        As I had to rush off to work afterwards, after I left, I remembered that we had forgotten to adjust it slightly as there was a small hole at the joint to the old system
        (The slit at the end had not been covered over completely by the other pipe)
        So Im hoping that once that is sorted out, it shouldnt be as boomy, if it doesnt, then it will have to go as its WAY too loud and bassy around 2-3k revs.
        Anyway, we took off the rear silencer and rather than cutting it so it kept the other box, we made up a pipe to suit.
        Sorry no pics of it finished completely, or of any normal rear view pics showing the pipes. I will sort those tomorrow, and an underside one when we adjust it.
        • FITZY
          • Sep 2004
          • 194
          Are you not running a middle box then??, I have a milltek cat back on my avant which is a 2 box system and thats just a bit louder than stock (in a nice way).
          Paul
          94 S2 Avant, Crystal Silver, slightly modded
          89 Vw Golf mk2
          12 Mercedes e250cdi, silver, daily commuter
          • dest
            • 4287
            Correct, no middle box.
            As I already said, Im 99% certain the volume is due to forgetting to adjust the centre joint where a hole was visible.
            The combination of a 40 min drive to work, with 25 mins to do it in, got the best of me and I rushed off without sorting out the gap
            So I will reserve judgement until it is adjusted
            • T2Andy
              • 1903
              I know of an AVANT with a full miltek which is also very boomy at cruising speed .
              • FITZY
                • Sep 2004
                • 194
                You'll have to let me know how you get on with it once it's sorted , If it's not OTT sound wise I might have to bin my middle box :mischeif: .
                Paul
                89 Vw Golf mk2
                • dest
                  • 4287
                  Mine didnt seem too bad at 60mph+, if anything, it got quieter.
                  It was at its loudest around 2800rpm
                  • dest
                    • 4287
                    • PeteRR
                      • 1326
                      That sounds similar to the Stromung on my S4. It's a 3" system with no middle box.
                      About 2500-2800rpm it is at it's loudest. Though cruising at 60 with the sunroof open I get a wonderfully tuneful, subtle warble.
                      • bullet
                        • Jul 2004
                        • 25
                        I'm deciding to get a cat back milltek for my s2. before i buy it i was wondering if someone could post a sound clip.
                        thanks
                        • dest
                          • 4287
                          Once I get that joint checked out, I should be able to sort afew clips
                          • A80Avant
                            • 10873
                            • Country: Greece
                            i have the milltek as well with both boxes.it is loud from 2000-to 2800rpm then quiets down for the turbo to kick in with it's noise...
                            I could do without the low range boom.Im thinking of either modifiying the milltek boxes,or replacing them
                              can you not just use a bung of some kind?
