Woo Yay!! Sold my S14!
  • Acidburn
    • 13459
    Any pics? Standard?
      Will post up some pics later once he's been santitised to my standards
      he's fairly stock, got koni adjustables and -40mm springs, with some fairly scruff 17" multispokes. A few little bits of rust starting, the lower door trims need replacing and theres a little crease on the rear arch.. other than that the paintwork is is great nick He's had new rad, middle section & backbox recently Needs new disks and pads but that's cheap as chips
      A few things that i might ask in the technical section, the ABS cancellation switch i think is bust - it doesnt work, but the ABS and warning lamp work fine, some bulbs gone in the dash switchgear, coolant temp gauge doesn't work at all, also its got a sticky hydraulic tappet... other than that seems fine and well
      planning on modding the airbox to release the L5 howl
      Any advice?
      I was planning on drilling some holes coldside along the inner wing side of the airbox :mischeif:
      Last edited by Error404; 11 August 2007, 09:00. Reason: correcting my own stupidity :p
      • 20vQC
        • Aug 2007
        • 684
        • Current: Italy
        CONGRATS Error404!!!! Welcome back to the Audi Quattro family hehehe So...you bought the car with some 17 inch wheels??? NICE!!! I have the ugliest rims that Audi has...the stock 15's 6spoke Quattro rims
        I did not get that about the airbox... can u explain it to me!! Thanx ! and congratulations again though! We're waiting for the pics!!
        - Looking for a S2
        - Lancia Dedra HF turbo i.e. (4sale)
        - Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
        • Acidburn
          • 13459
          I know its quite short as it would not load up the whole video but check out my 20v quattro sport, it had a huge ram air filter fitted in the place of the airbox sounds lovely.
            Ummm.. yeah thats what mine sounds like now
            Drilled a load of small holes along the wing side and frint of the airbox, and routed some flexi ducting from down near the tow eye to feed in cool air. sounds awesome.
            first mod done, only had it 12 hours
            • Acidburn
              • 13459
              Not bad, we actually was going to make a sports exhaust for my car but found once we'd chopped the quattro back box off the noise did not go up much so just made a s style pipe with some 3 inch scorpion trims and reveled in the weight loss from having a lighter "back box"
              • 20vQC
                • Aug 2007
                • 684
                • Current: Italy
                #22
                Dudes!!! I don't get that airbox thing !!!! do you have any photos of it???
                - Looking for a S2
                • Acidburn
                  • 13459
                  Might be one somewhere in the mods/forum section. Basically you know the air box with the filter in it. This has either had the opening at the front widend or ON THE COLD SIDE AWAY FROM THE ENGINE, some holes to let more air in, drilled into the box under the filters grove.
