The project car is on my drive at the moment - it has no rear calipers on it, but i can probably get that sorted this week so it will be easily moveable..... it would just mean pushing them on and off the drive....
it sounds easy, but a couple things i'm not sure about i've highlighted in italics :-
When your sure its correct move onto setting the belt tension, the design is a bit crap so it will take a few goes to get it right. Don’t know how to explain in words what it should feel like, enough so it’s tight, but not enough to overload the water pump bearing. If it’s too loose the distributor will rattle at idle, too tight and the water pump groans and won’t last long.
