A little something else to keep me busy.
I reckon it was a bargain at £200 with that nice spec and decent headlights etc, even if it needs a new engine, as I've said not the end of the world.
I've dealt with blocked up oil pick ups on a few 20VT's, if caught early enough then it's not a problem. If the engine sounds rough and the oil light has flicked on a few times that does not bode well, the head in general will have been staved of oil. First the tensioner looses pressure, the cams and lifters are staved of oil and then the main bearings cop it, pretty much in that order.
All you can do is pull the sump and cam cover off and have a look. A replacement 20VT engine isn't expensive so even if the motor is toast it's not the end of the world.
I had one fail with no warning whatsoever whilst driving a B5 A4 quattro just like this, that totaled the head causing the cambelt to snap stranding me beside the M5 for eight hours.
I also have a good 180bhp 20VT engine sat under my workbench should you need one.Leave a comment:
Been there with one of those. Mine had bent valves from the same. I might still have some used straight valves if you need. Odd ribe bit for head bolts. I have one of you need.Leave a comment:
Done lots of reading on this. Oil starvation caused by blocked strainer causes hydraulic tensioner to fail, causes loose chain and noise plus rough running
Last time I heard it run it sounded like a diesel, actually if you've seen the film 4 Lions, it sounded like that car. It now has a skreech which could be the serpentine belt idled seized.Leave a comment:
I did the cam chain on my on my A4, the only symptoms was a slight rattle and the revs fluctuated on idle. It never brough the low pressure warning light on. I think you have another issue.Leave a comment:
So, thanks to Newsh and his neighbour Yann for sending this my way.
I've made an initial assessment and it quite good body wise for age and mileage. Nice spec with half leather Quattro script seats.
The main issue is the engine. I haven't actually heard it as I don't want to run it until I've looked inside but apparently sounds like a bag of nails and oil light is flickering. Plan is to drop the sump and clean the pick up plus inspect the bottom end. Then remove the rocker cover and have a poke around in there. The timing chain tensioner might be making all the noise. We will see. Pics to follow as usual.
