A little something else to keep me busy.
Good job there Dave as it was a fair bit of work... I'm not super up to date on B5 prices but In think you should get your money back or even be in profit.Leave a comment:
Passed mot with no advisories.
Now for sale if anyone is interested. It owes me £1800. Happy just to get my spend back.
Sent from my iPhone using TapatalkLeave a comment:
Glad you got thaf outer race out with damaging anything.
I like your new centre caps left plain, looks excellent.
All back together. Discs and pads have been changed very recently and are TRW which I rate.
New windscreen coming Thursday then mot time.
So this morning with fresh head I thought I would have one more go before I destroy my abs sensor.
And it came right out. Strange.
And new one went in nicely.
This is the best £50 I ever spent.
So the driveshaft flange came out no problem.
But pouring oil into the opening proved not to be an option. There are bearings in the way and it just runs straight out.
So I had to get brave with the fill plug.
I tried hammering in a star socket but it just rounded out.
So, with some fire safety precautions in place, I went for it.
Once the bolt was welded it was just hand tight. I've used this method a few times and it's never failed. I think it's the extreme sudden heat that does the trick.
Now I can get on putting the new seal in and re filling with EP90 oil.
I'm surprised that outer race stayed stuck after the bead of weld they normally pretty much fall out then, needs to come off then go in a press you may end up destroying the ABS sender but it that's what it takes then so be it.
This little project has been waiting patiently whilst I finished the Ur, serviced and fixed our B5 tdi Passat, serviced the boys polo and serviced and fixed the wife's Passat. Phew! I have been busy.
So, the ramp is free and on she goes for rear wheel bearing. If you remember from before, I had to abort this job as I found someone had rounded out the hub bolt. Nice!
Cleaned up ready for welding.
You get the idea.
Worked a treat.
Now the seal on this side of the diff has been leaking for some time. I removed the whole driveshaft and sprayed everything with solvent to clean it up.
I've drained the diff and the oil looks like it's original. So far the fill plug won't budge. Nervous grin. I can alway fill via the drive shaft hole as I'm changing the seal. Don't really dance welding something in the fill plug here as it's right next to the plastic petrol tank.
So, on to wheel bearing. It's proving to be rather stubborn.
My tool won't budge it.
So I welded a bead inside. Still no budge. So I decided to remove the hub carrier. Abs sensor is seized. Cry.
Don't we love working on these old rusty wrecks.
Those look fantastic. Buy cheap Audi centre caps (eBay item 155072006741) and remove the rings then glue on your new caps?Leave a comment:
My local engineering guy made me some new caps.
I just need to work out how to get the rings on them. Maybe stickers? Not sure yet. However, they look pretty cool plain.
These look great. Always loved them on both B5s and C4s, really fancy the correct 8J versions for the S4.Leave a comment:
Wheels are back from blasting and powder coat. I went straight to the tyre place to get new tyres fitted. Called at my friendly engineering place and they are making me 4 new wheel caps in aluminium.
