Are there any bolt together front brake upgrades using OE parts options for the front of a B5 TQS that doesn't require converting to S4 front uprights?
Looking for something to go under 16" wheels so I can still run my winter rims, ideally around 320/330mm and four piston calipers though I'm happy to listen to any options.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.
You can use a 4B caliper mount and discs (312mm) with the oe 288mm caliper. I think its the cheapest and quickest upgrade on the b5 without converting to front uprights for big brakes. You can also use 4B big front uprights, will fit perfect to the B5... I used Aluminium big front uprights for my street b5
A few years ago I tried fitting an original TQS 17" bolero wheel to a B5 S4 and it didn't clear the front brake caliper, so that might be an issue for your 16" wheels too if you put a larger caliper on it.
The only OE solution I know is mk4 R32/mk1 TT V6 front brakes (2x43/44 mm pistons). They are a straight bolt in solution, but they are heavy cast units and minimum wheel is 17". The calipers used are the same as B5 RS4, Passat W8, E38 750 and I believe X5 4.8is and many more, with different carriers of course.
When I searched the web a few years back I think somebody mentioned some Seat Ibiza or Cupra front Brembo brakes with OE adapters that somebody allegedly bolted on, but I haven't looked into it myself. The R32 brakes I have bought and do bolt on nicely. Can't comment on which discs to use as I haven't installed them due to running 16 and 15 inch wheels.
