My B5, the Lifer........
  • RS2ZuidAfrika
    Registered User
    • Jun 2012
    • 63
    • Home: South Africa Current: Palestine
    #61
    Hey bru. great work as usual. finding the time for all this is itself a gift, let alone the talent you have!
    tell me more about your life in SA!
    • Twenny Benson
      • Jan 2011
      • 278
      Howzit Brah, thanks for the kind words once again, time is one thing I'm sure we all wish we had more of, I must admitt its getting increasingly more difficult to find the time to work on the car, hence the slow progress It'll get there in the end though.
      Well were do I start! I spent 5 years working as project engineer for a company in Port Elizabeth, luckily I managed to find myself all over SA and most of East Africa doing various bits & bobs. Spent plenty of time in Cape Town as well which I love, if I win the lottery I would without doubt spend my summers there. Travelled the Garden route numerous times in numerous different cars and what an amazing drive that is! Took the route through natures valley most times, one of the best roads I've ever been down dodging the baboons whilst carving up the switchbacks under the canopy lined roads without a speed camera in sight! A close second was driving through the valley of a thousand hills around Lady Hammersmith in KZN! I often wonder why I left and always think back fondly. I use to ride alot of motocross & enduros whilst I was out there and I've never come across terrain that can rival it, the vastness of the bush is just unreal! I will return for a holiday one day soon, made so many good friends, its time I returned for dop en tjop Good times!
      2000 B5 A4 Quattro Sport ~ 2.0 20V GT30R ~ Gone
      1993 S2 ABY Coupe ~ Gone
      1989 2.2E Coupe ~ Gone
      • Witrotseun
        • Feb 2012
        • 22
        • Country: South Africa
        #63
        Makes me proud te be a South African...
        Can do with some dop and tjop myself right about now.
        • TimE-J
          • Jul 2009
          • 1292
          Any more updates? Are you still planning to go to Anglesey Circuit this weekend? Weather looks like it might hold out.
          96 S2 aby Coupe. Rebuild Project
          96 mk3 golf tdi daily.
          • Twenny Benson
            • Jan 2011
            • 278
            Yes an update is needed, once I get my PC back together I'll post some progress. I've been moving house and my whole world is upside down at the moment! I would love to go to TA but I just can't make it unfortunately. I haven't made it to one TA event this year and I usually get to two or three rounds every year and have done for the past 3-4 years
            • Twenny Benson
              • Jan 2011
              • 278
              Rightly so buddy, cracking place to be, great people, great weather and the braaivleis is unreal
              Anyway, massively overdue update.
              Moved into the new gaff. I've promised myself that I won't let the workshop turn into a pile of Audi again. I started out in the right way, painted the walls, floor and got the electrics in.
              Then all the stuff from the old workshop migrated across along with the Audi.
              So since the last update I've had a delivery of bits from the states. Nothing too spectacular just a block breather adaptor, overbore 1.8T headgasket and a Vernier pulley. I've always run a european 2.0 20V NA headgasket as the bore in the head gasket matched my over bored 1.8T however the compressed thickness wasn't anywhere near thick enough so that should be solved now.
              The Block breather adaptor will allow me to run AN fittings from the block and from the rocker cover once I weld the fittings on. The engine seems to struggle with crankcase pressure so this should help out.
              Ive also bought quite a few AN fittings to replace all the boost related hoses from jubilee clips to AN aeroquip style fittings.
              Turned down some weld on fittings and welded them into the hose barbs on the inlet manifold.
              And welded up some of the small take offs that never sealed all that well.
              Job done!
              Next the cylinder head came off
              New head gasket fitted along with the new pulley.
              Now one of the reasons I went for the vernier pulley was due to the fact I couldn't align the TDC marks no matter what I did. It was always half a tooth out. Now i've run the car with the cams slightly after & slightly before TDC, both ran different so I decided to dial this out with the vernier, turns out it was 6 degrees out!
              Be interesting to see what its like now
              Made a start at the new catch tank, my ally welding needs more practice but itll get the job done for now! Not pretty I know.
              Obviously a work in progress, still need to cut some more pieces and order the weld AN-10 fittings for the can & rocker cover.
              Some more parts that have arrived and bits I've changed.
              60 PSI gauge its better than running 30 PSI on a 30 PSI gauge I would have no idea if i was over boosting! Plus I was always told that spec'ing a gauge to run at full scale deflection was a very silly thing to do.
              Wastegates converted to AN fittings rather than banjo's and jubilee clips which I hate with a passion.
              Cleaned up some gauges from my old 2.2E 10 valver coupe
              Cleaned up my calipers
              Converting the compressor housing to AN fitting, another jubilee in the bin
              Next job is finish off all the electrics with the switch panel, I have most of the bits now. Then I can connect the battery and fingers crossed everything will be fine.
              Thats all dudes, updates should be more frequent now as I'm desperate to drive this thing again
              • s2_bo
                • Oct 2005
                • 6067
                #67
                Just read this thread start to finish! Amazing detail and top notch photos!
                Thanks for sharing.
                91 S2 coupé - RIP
                98 S8 - Luxury barge
                • TimE-J
                  • Jul 2009
                  • 1292
                  Fantastic update, I will look great with all the new fittings.
                  • andy10v
                    • 5996
                    A think you may have a fetish for fittings
                    Sold ABY-stock
                    • RS2ZuidAfrika
                      Registered User
                      • Jun 2012
                      • 63
                      #70
                      I second that
                      loving the attention to detail, once again. Those calipers look brand new and BOY would i love to get rid of jubilee clamps!
                      This is going to be bulletproof with all the little nuisances converted to AN.
                      Goeie Werk!
                      • Twenny Benson
                        • Jan 2011
                        • 278
                        Thanks for sharing.
                        Cheers matey. Its been slow going lately but hopefully progress should speed up a bit now, I've finished all the painting & wall papering for her indoors.
                        It certainly will look alot neater when I'm done. I do like those AN fittings, much nicer than jubilee clips
                        I second that
                        Goeie Werk!
                        I have to admit that I have a soft spot for anodised aluminium parts coupled with nothing but pure hatered for jubilee clips, there *****, plus chasing constant small boost leaks from un-sealed connections just gets boring! The standalone ECU I run doesnt have closed loop fueling enabled, I was advised not to incase the lambda sensor went squiffy and messed up the fueling and took the motor out! So with open loop fueling any variances in the boost/air delivery due to leaks sends the AFR's way off, it just gets tedious So hopefully with everything boost related converted to AN fittings the problem will hopefully go away, it bloody better do at this cost! The goal is obviously to make the set-up as bulletproof as possible .
                        And those calipers came up a treat with a bit of cleaning and some hi temp sealant
                        Started out like this.......
                        To this....
                        Note the Aston Martin symbol cast into the caliper, these were removed from a Ford GT!
                        More updates soon.
                          Cracking work as usual mate
                          what are your plans for the new man cave?
                          • Twenny Benson
                            • Jan 2011
                            • 278
                            Cheers fella
                            Plans for the man cave aren't much to be fair. All I've done is paint the walls & floor, put a light & some sockets in and thats it really. Its a rental property so don't want to go over board. I will be purchasing a house mid next year that WILL have a big garage, so will have to hold out until then.
                            Hows the TIG coming along?
                            • soupie69uk
                              • Jan 2006
                              • 3
                              Just had a read through your thread. Some superb work there!
                              I have a 1.8T but its pretty much standard when comparing to yours!
                              • terrybullwon
                                • Mar 2006
                                • 8782
                                what size are those bolts on that cam wheel? They look like something i could really use.
                                Making good head way
                                Chef
