Hi all. Changing a seized rear calliper tomorrow on my B5 RS4 and I like the help on this forum so thought I would ask here.
I wanted to check the order. I have read it's rear right, rear left, front right and then front left.
I have also read that they have separate pipes so if I am changing one calliper I only need to bleed that calliper !!!!!
I have a pressure bleed kit that works from a tyre and having used it before know that I need to have just a little pressure from the tyre not loads. Just wanted to confirm the order and check if what I read about doing just one was true.
