A question about the Motronic ECU with a larger turbo
Whilst I save up some funds to go towards getting my URS6 re-mapped is the standard ECU and injectors capable of safely running standard boost in the interim period?
Maybe I could fit a standard wastegate spring and disconnect the N75?
I ran my 2.5 with a 3071 on a stock ecu and stock injectors until the engine was run in, it coped fine, just avoid boost be unplugging the N75 as you said.
Out of interest what is the standard boost pressure? I believe my car has a 1.9bar spring currently fitted
