Urs4 drivetrain noise
  • AUDIDAVES4
    • Nov 2011
    • 118
    I have been rebuilding my S4 over the last year and finally took it for a little spin along the road last night, pulled away from the house in 1st then into 2nd no problem, I shifted into 3rd and put the foot down and there was a knock then a scraping/ grinding noise from the centre/rear of the car, I stopped reveresed and headed back to the house the noise had stopped, I repeated the drive and the same happened again, next time after that I drove without hard acceleration and there was no issue.
    Any ideas?? Could it be the prop bearing?
    any advice would be much appreciated.
    Thanks
  • Thecrispynoodle
    • Jul 2012
    • 269
    If it sounds like it’s being caused by something rotating rubbing something else then it’s likely loose or bent heatshield hitting the centre driveshaft. Hopefully nothing worse. More torque in 3rd so more movement so more contact.
    • Thecrispynoodle
      • Jul 2012
      • 269
      Also you will be able to see the shiny scoring on the centre driveshaft from where it’s coming from if so.
      • AUDIDAVES4
        • Nov 2011
        • 118
        Removed the prop shaft this evening and the rubber round the bearing fell apart, however there doesn’t appear to be any scoring on the shaft but the bearing needs replaced regardless.
        • Thecrispynoodle
          • Jul 2012
          • 269
          Oh dear. Time to overhaul the whole thing then :-) Mine has some play but it’s still intact.
          • rynaqui
            • Mar 2012
            • 2752
            • Country: Malta
            Good to change all the outer and center joints as well whilst there. Did that in my car some time ago and made a great difference
            1996 S2 ABY Silver
            • AUDIDAVES4
              • Nov 2011
              • 118
              Where’s best to get the rest of the joints? Price??
              • Thecrispynoodle
                • Jul 2012
                • 269
                Find driveshaft specialists near you as the centre joint will need to be unstaked and rebalanced, All new CV joints, bolts and support bearing gonna cost you £200-300 in parts plus whatever labour is involved.
                • vag_noob
                  • Nov 2010
                  • 72
                  • Country: New Zealand
                  If the CV boots are not torn then there is probably no need to replace the driveshaft CV’s or boots. But you probably want to repack the CV’s with new grease. The u-joint is not necessarily bad either. If you replace any of these you will need the shaft balanced.
                  If it is just the center bearing then it is an easy fix.
                  • AUDIDAVES4
                    • Nov 2011
                    • 118
                    Everything else appears to be ok so it’s just the center bearing, I do the work myself so no labour cost either. I have the new bearing so should get it built back up this week.
                    • Thecrispynoodle
                      • Jul 2012
                      • 269
                      Where did you get your centre bearing from?
                      • AUDIDAVES4
                        • Nov 2011
                        • 118
                        On eBay, it seems to be decent.
                        • AUDIDAVES4
                          • Nov 2011
                          • 118
                          Car built back up and road tested this evening, no knocking sounds but there seems to be a whine from the rear diff
                          • Thecrispynoodle
                            • Jul 2012
                            • 269
                            I’ve seen those but have a larger external support diameter presumably that wasn’t an issue?
                            • AUDIDAVES4
                              • Nov 2011
                              • 118
                              It has the same dimensions as the one that came off
