Hello, cant get my tps correct, its stuck on 100 % i have change tps sensor, same problem, checked wire its good, i have not check volt, i get it to calibrate one time…, i have spare vems ecu for 3b and there is no problem to calibrate tps…, (just testing), where can problem hide? Ecu? Have parts to ecu..
I will try fix it, if not can i modify 3b vems to my s4?
This gallery has 1 photos.
