Urs4 idling rough and not boosting normally
  • Palakasana
    • Aug 2025
    • 5
    So, I have a 93 urs4 and I've been having a problem with it for a while now.
    Its running/idling rough, just like running on 4 cylinders, but still running rich. Its running on all 5 cylinders though
    And the boost problem is that the s4 doesn't boost over 1.5 bar looking from its own "computer"
    The s4 is "basically" stock, only physical change is a fsi conversion, but it has ran fine with/without the fsi conversion. And it has a chip, I don't have knowledge of what chip it is, but it has ran fine with that also.
    The car doesn't give any fault codes, apart from a 65535 from the ecu, meaning "total ecu failure", but that can be from the chips checksums?
    So, what i have tested so far:
    - Maf has been tested with some bentley guide, and pulling the connector of doesn't help (from reading forums, many say if its a boost leak, unplugging the maf helps)
    - injectors/fuel supply
    - Boost leaks hoses etc., except the intercooler
    - Plugs/coils
    - ECU wiring/insides, nothing seems to be wrong
    - N75 tested
    All new ideas welcome, i can test some components again if that helps, but I don't know what to look for anymore.
    • Dec 2017
    • 5991
    Do a boost leak test from where the maf connects ( smoke machine works very well) up to 10 psi. Have you replaced the valve on the pcv circuit? Have you done a fuel volume test?
    • Palakasana
      • Aug 2025
      • 5
      I will do a boost leak test this week, my friend has a ”leak tester” set, but i have tested the fuel pressure and the volume, both are within specs. For the pcv, i havent yet changed the pcv valve
        • Dec 2017
        • 5991
        Audi still sell the pcv valve. Best get one from them. Aftermarket quality is dubious.
        • Crasher
          • Nov 2018
          • 139
          Febi valves are good.
          • tekstil
            • Jun 2011
            • 104
            Engine timing? O2 sensor and its circuit?
            • Palakasana
              • Aug 2025
              • 5
              Engine timing ok, 02 sensor ok, tested and working. Circuit also working fine
              • Palakasana
                • Aug 2025
                • 5
                checked both the one under the IM and befind it, the one under was clogged (now open, cleaned it) and the one behind was broken, ordered a new one, will be arriving next week. I might in the meanwhile test for leaks.
                but now it runs a bit better, still quite jerky, but the breather valve might solve that?
