Hello, I would like if someone could help me with the oil deflectors from the cylinder head, I have searched on different sites, ebay, etc, but no longer available. 034 103 553 D. Is there only one or do I need two?
Need help! 034 103 553 D
If your talking about an 20V turbo engine there is one that fits directly under the oil filer cap, so you only need one.
And to be honest that's far from essential, I tend to remove them if they're old as they go brittle and end up in bits in the head and sump.1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS. -
During the restoration of the engine it was dropped and broke into a hundred pieces. I wonder if it has any negative impact in the long term and if, somehow, someone can help me with this part, or a link where it can be purchased. yes, it comes from a urs6 20v. thanks!Comment
Delete it. Its only purpose is to prevent oil splashing out if you remove the oil filler cap when the engine is running. They become brittle with age and fall apart.Nothelle S2 Avant
Urs6 plus project goneComment
Exactly that. It's basically a useless time bomb.
Unlike the one's on some later Audi engines it's serves no useful mechanical function whatsoever.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
As a mechanic who's had to pick out broken bits of plastic from way too many old Audi engines.
All that that shield does is prevent you from burning yourself with hot oil when opening the filler cap with the engine running, that is it's sole function.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
That can be the case with some newer Audi engines but not with old 20VT engines. If it really concerns you fit a new genuine Audi one and renew it every ten years.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
