S6 Custom Suspension?
  • RichLV
    • Mar 2015
    • 872
    • Country: Latvia
    Originally posted by geneandbolly
    Could either of you chaps post a photo of how your cars sit, please.
    Thanks.
    There ya go.
    Keep in mind that I don't have Bilstein shocks. I'm riding on KYB Ultra SR.
    • geneandbolly
      • Sep 2013
      • 1356
      Originally posted by RichLV
      There ya go.
      Now, that's what I'm after - your car sits beautifully!!
      Thanks for the photos and the information..
      Craig
      1997 Audi S6 - The Purple Helmet!
      • bn-01-wso
        • May 2009
        • 471
        • Country: Romania
        Did you use some spacers in the back? I also have EW1516002HA in the back with KAYABA ULTRA SR and it sits too damn low. I am confused
        Your's sits perfect on the Avus.
        • RichLV
          • Mar 2015
          • 872
          • Country: Latvia
          I bought it like that. When I was disassembling the rear suspension, I did not notice any spacers.
          • Cordoba16vt
            • Apr 2014
            • 182
            • Country: Bulgaria
            #20
            Winter mode 225/50/17
            next photo is with springs installed as is , i.e no 15mm spacer. Car rode like a dream ! but looked bad
            as it sits now on 235/45/17
            Sent from my SM-A510F using Tapatalk
            • vantsen
              • Jul 2023
              • 17
              Originally posted by Cordoba16vt
              Well it is very important what rear springs have come with order under this common order number E1528-140, I did my homework when ordering mine and found this pieceof info -
              Ausführungsbezeichnungen:
              Fahrzeugzuordnung:
              Vorderachsfeder:
              EW 1515101 VA
              4-Zylinder
              Vorderachsfeder:
              EW 1515001 VA
              5- und 6-Zylinder, S4 mit Klima
              Vorderachsfeder:
              EW 1527001 VA
              5- und 6-Zylinder,
              S4 mit Automatik und/oder Klima,
              S6 4,2L
              Hinterachsfeder :
              EW 1516002 HA
              alle außer Avant
              Hinterachsfeder :
              EW 1521002 HA
              nur Avant
              In short there are 3 types of FRONT springs , and 2 types of REAR springs , all under the same order number
              In shortER >
              EW 1527001 VA
              EW 1516002 HA
              are the corect part numbers of the springs to be used on a sedan . ( and YES I did have to reposition rear perches - chose not to do grooves on the shocks but made 15mm spacers , bear in mind that as you raise the rear , there is more load on the front and it drops a little so it is not that bad. As for ride and handling , I am satisfied for a road daily car)
              pls see attached file where spring size, ttl height etc are outlined.
              Hello
              On same deal planning to change springs, these are correct right ? Hope you guys are still active hehe.
              • vag_noob
                • Nov 2010
                • 72
                • Country: New Zealand
                #22
                I like mine...lol
                This gallery has 1 photos.
                • vantsen
                  • Jul 2023
                  • 17
                  mine is not that bad, but still, annoying even when accelerating it squats hard
                  • vag_noob
                    • Nov 2010
                    • 72
                    #24
                    I put Koni shocks on the front about 14 years ago, stock springs, huge improvement in roll.
                    • vantsen
                      • Jul 2023
                      • 17
                      Got any pictures of the car how it looks /looked ? and there is different stock springs, which ones ?
                      • vag_noob
                        • Nov 2010
                        • 72
                        #26
                        see photo above, stock springs = stock ride height. I don't know what the differences in OEM spring rates are. Everyone lowers the vehicle, except for me..
                        • Cordoba16vt
                          • Apr 2014
                          • 182
                          • Country: Bulgaria
                          #27
                          Originally posted by vantsen
                          Hello
                          https://eibachshop.com/index.php?p54...nt-a6-a6-avant
                          I would use correct springs for 4 cyl or 6 cyl at most as S6 engines are much heavier and springs are diferent. I am not sure what will hapen, but apart from coilovers - only correct for model - Eibach springs have worked for me. If you want lower and more sporty ride , Bilstein B8 is the way to go on the same spring ... My car is on B6 but as I mentioned it is a daily, so I prefer softer but tighter ride.
                          • vantsen
                            • Jul 2023
                            • 17
                            had previously v6 2.8 AAH engine, now its 1.8t AEB, so the weight different is not that much. Id like to have it even or front is lower then back, right now its reversed, back more low and the front is up - so the eibach setup should do the trick then ?
                            • Cordoba16vt
                              • Apr 2014
                              • 182
                              • Country: Bulgaria
                              #29
                              As C4 are front end heavy , what Eibch has done is lowered the back in order to transfer weight to the rear and reduce understeer. The way to correct it for good look purposes is to raise the back by instaling a perch on the rear shocks, on bilsteins there is a groove and a ring that fixes the srping holder plate. in my case it was 15mm if I remember corectly and bear in mind that it is not a direct ratio - 15mm perch may or may not raise the rear by 15mm, so it is a bit of trial and error. rear geometry and condition of bushes, etc also plays a role in rear end height.
                              • Cordoba16vt
                                • Apr 2014
                                • 182
                                • Country: Bulgaria
                                #30
                                Also, try this, grab the car by the boot and try and raise the rear by hand 1 cm and see how much weight will transfer to the front
