Help A4 convertible electric roof failure
  • 220bhp
    • 2578
    • Home: United Kingdom
    My wife's a4 cabby's electric roof failed today. She put the roof down to cart a box to big to get through the door, and it wont go back up.
    I haven't a clue what to check. So any help would be appreciated.
  • mdz
    • Jun 2012
    • 775
    • Country: Latvia
    Pulling codes and checking actual readings with Vagcom/VCDS will be the best to start with. Haven't got my hands on A4 cabby, but from my experience with 80 cabby electric roofs, there's tons of microswitches and conditions that can cause roof to stop working.
    • bluequattro
      • 2960
      Boot wiring is usual culprit for 80 cabs in my experience.
      Many people blame things from the boot lock to the handbrake!
      Can you manually close the roof?
      Is it electric or hydraulic?
      • 220bhp
        • 2578
        Its electric ,and I have managed to close it ,but there are warning lights still flashing.
        Now the boot wont open.
        • bluequattro
          • 2960
          Sounds like boot wiring fail-happens on most 80 cabs I buy.
          You need to find the break in wiring and repair
          Of course you need to get the boot open first
          On the 80 if you and the ski hatch bag out you can use long extension bars and
          undo the boot lock from the boot lid
          Not sure if can be done on a4 though
          • Monkeymagic
            • Mar 2012
            • 3419
            The wiring in the left hand side wiring bellows will be damaged as blue Quattro has said.
