So an issue that is slowly getting worse on the family wagon B8 TDI Avant....
It would sometimes not start (or even try to start, the ignition just turns back off) when you press the key. This has now progressed to you having to almost push the clutch pedal through the floor before it will then crank.
My initial thought is/was the clutch switch (which I have learned is part of the master cylinder) but,,, when stopped at traffic with the "auto stop start" the engine fires back up when you press the clutch normally.
So ..... Are there 2 switches within the master cylinder or should I be looking somewhere else?
Any help is much appreciated!
Jase.
Jase.
