So... long time since posting here... figured I would share a little episode on the B6 S4 that happened a week ago. I am still not 100% perfectly back together again, but maybe some other owner (with VAGCOM / VCDS) can help solve the final part of the puzzle.
Been travelling loads lately and so the car has been seeing little action of any sort. I went to it one Saturday morning and had the awful sound of dead battery when I tried to fire her up. I felt sure that I must have left something on which drained it over a week, so got out the jumper back and the engine roared into life, but with very odd side effects... Namely the big red flashy oil pressure warning lamp for one thing and no tacho working... no indicators either and EPC/ABS lights on as well.
Long story short - turns out the low battery voltage caused the instrument cluster to forget its coding & adaptation values and I had to slog through that on VCDS for the first time - the recent versions give lots of help along the way so you enter the right codes that align with various options fitted etc. The most important ones are the CANbus entries in channel 60-61-62... only when those were correct did I get instruments & indicators working again.
I have the cluster (8E0 920 980 L) coded as 01400 now which I believe is correct for my setup, but I still have a "Terminal 15 - Implausible Signal - Intermittent" fault code which refuses to clear. I also don't have the trip computer working properly - I get data for modes 1 & 2 but its way off whack - I set my Channel 19 = 31010 (Highline DIS2 with Ambient Temp Sensor) and set Channel 03 = 100 for default fuel calibration.
I have checked the power supply unit (above driver pedals) is good but I am wondering if some other undocumented parts of the display controller are corrupted - the steering wheel angle sensor threw a similar code until it was put thru the basic settings to calibrate it again.
BTW - root cause was just chemical collapse of the 5yr old crappy battery that was fitted before my time. It refused to recharge and I verified the car was only drinking 40mA when resting. One Bosch S5010 / 110 battery later and we are back in business. That is physically the biggest battery (315x175x175) you can get into the B6 S4 - there are movable stops in the tray if you wish to go smaller/lighter.
Any other B6/B7 S4 owners out there with trip computer and the colour display who can check their codes on VAGCOM ?
Cheers,
Paul
Cheers,
Paul
