Anybody know alternative for G 055 145 A2 gear oil. It have some "special" additives compared to normal gear oil. Oil goes to centre differential (torsen) in ZF tiptronic gearbox. Price for one liter in Finland is ~160-180€/L, U.S ~90$/L, germany ~120€/L. I can´t find any febi,castrol,mobil etc alternative.
Alternative gear oil
Anybody know alternative for G 055 145 A2 gear oil. It have some "special" additives compared to normal gear oil. Oil goes to centre differential (torsen) in ZF tiptronic gearbox. Price for one liter in Finland is ~160-180€/L, U.S ~90$/L, germany ~120€/L. I can´t find any febi,castrol,mobil etc alternative. -
Castrol Syntrans Transaxle 75W-90 was recommended to me as well. The newer gear oil will be far superior to what was being used back when these cars were new so will not require any additives.1995 Audi S2 AvantComment
For centre differential G 055 145 A2 Transmission oil is with 3% Sturaco additive. Not sure what it does and is it really needed. At least older torsens did not need this additive. Castrol Syntrans Transaxle 75W-90 is OK for front and rear differentialComment
Remember that it cannot be GL5. Too slippy. Opie gets it wrong.
If you use GL5 baulk rings die in a couple of years and the change is slow.
GL4.Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8Comment
Yep as said you want gl4 for gearbox and gl5 for the diff. Both are 75w90 but you don't want to get them the wrong way round.
Here's a photo of what I got, gear oil left, diff oil right1995 Audi S2 AvantComment
Rob..
87 UR 20v ABY
97 S6 Avant
