I was getting intermittent faults (with MIL on the dash) for insufficient air flow in Bank 2 -that's left side for the uninitiated.
So... A quick look at the manual tells me there is vacuum controlled actuator on each bank at the back of the head. Both actuators are triggered by an ECU controlled solenoid.
The fault always pops up on Bank 2 so I know the pump and solenoid are good. I found the vac lines and followed them back to the actuator. The first touch of the hose where it meets a 90 degree rubber elbow into the valve and it breaks off. Ahah... That hose has been cracked and leaking enough to trigger the fault now and again.
So I was just able to prize off the elbow and remove the remains of the broken hose and had enough length to reroute it slightly and refit.
That *should* be that one sorted for now. If I ever get round to a remap then I shall be sure to ask for deletion of the secondary air system - it's a PITA.
