Wheel cleaning recommendations
  • dm80
    • Apr 2005
    • 812
    Hi folks..
    My re-conditioned stock 3B alloys are ingrained filthy. The laquer has been removed and they polished up perfect. Over the winter weeks though they're in a sorry state. Anyone recommend a decent cleaning product apart from elbow grease for these?
  • PeteRR
    • 1326
    'Wonder Wheels' is one of the best cleaners.
    Quite acidic so don't use it too often and wash it off quick. You may need to use a metal polish to re-bling the bare alloy afterwards though.
    • s2driveruk
      • 12696
      Hi, before the rs4's i used to have bare 3b alloys, I found any wheel cleaner was ok to get the worst off with and then use a bit of metal polish to bring back the shine or if you can't be bothered over winter, cover the spokes with some light oil to stop the dirt sticking so much, then come spring when all the salt is off the road, use a bit of wet and dry to get the real ingrained stuff off, really really fine grit and they come up great!!!
      1992 3b S2 Coupe
      • ericd
        • Nov 2003
        • 1240
        Originally posted by dm80
        Hi folks..
        As mentioned use some metal cleaner (autosol, peek etc,), since the lacquer's removed
        you need something to seal them (that's why they degarded over the winter !) if you're not planning on re-lacquering, either some kind of wax , or some of the cleaners like autosol do a good job of sealing/protecting for a while, I'd go for "muc-off" (you'll get in halfords) it's a bit less harshthan wonder wheels since you're at bare metal already
        HTH
        • dm80
          • Apr 2005
          • 812
          Cheers for the recommendations.. car will be gleaming this time tomorrow..
          • Ski
            • 2591
            ooo i didnt know about the other products apart from cleaning products.
            I will check out this "muc off" to seal them up!
            ABY Coupe
            • ericd
              • Nov 2003
              • 1240
              I guess I've caused some confusion,
              Muc-off will only clean the exterior dirt/grime
              then
              Autosol/peek/duraglit etc will polish/seal the surface
              • Ski
                • 2591
                Yeah I knew that was just testing if your on the ball honest!
                ABY Coupe
                • HPmuirt
                  S2Forum April Fool
                  • Apr 2005
                  • 3014
                  The best product I have ever used on wheels (on the odd occasion that I was my poor S2 ) is a non toxix, citrus based product, designed as a degreaser. Sprayed on neat, it will desolve even the output of thrashed Textar pads and simply rinse off. You can leave it on untreated metal without it causing any damage.
                  You can also use it on the paint work by diluting it in with the shampoo/water if you want to remove all the grime, but you will then need to re wax and polish the paint.
                  This stuff was discovered bt the TiT forum guys and was sold to them by a TiT driver called WaxWizard who charged them £25 for a 5L can. It is soooo good that they all lapped it up.
                  Turns out, this guy was buying an industrial degreaser, designed for car valeting amongst other things, for about £5 for 5L and then screwing the Tit club
                  And the name....well, that is a trade secret, but the promise of a cold beer might tempt me to spill the beans......believe me, it is actually worth the £25 so £5 is a complete bargain
                  Cheers n
                  Si
                  Subtle mods here and there
                  2011 A5 3.0 TDi - Lava Grey
                  • Mikes2
                    • 1704
                    You can buy citrus based degreasers from bicycle suppliers. The one I use is by Finishline
                    Mike
                    http://www.s2-audi.co.uk
                    • vonbeck
                      • 2455
                      i use muc-off its very good just spray on and you can either use a sponge or soft brush to get the crud off some cycle shops will also top up your empty bottle for £1 less than buying a new one again so save your muc off bottle for next time
                      • ericd
                        • Nov 2003
                        • 1240
                        Cheers n
                        Si
                        The stuff is Virosol by Clover chemicals, use them to find you're local janitor/cleaning supplier , still around £6/5l , better than most of your brand options IMHO , been used by us in the trade for a while now, also worth trying some 'autogloss' if you can find it
                        • ericd
                          • Nov 2003
                          • 1240
                          bump
                          • Crawford_S2
                            • 1555
                            Last stuff i used was Meguires wheel cleaner, its pink, comes in a trigger spray. Good gear
                            Ragusa Coupe gone!
                            • ericd
                              • Nov 2003
                              • 1240
                              Recently got 5L of this delivered for £15, still unbeatable for most cleaning jobs, especially wheels, patios, etc
