My Car Zymol'd
  • ericd
    • Nov 2003
    • 1240
    for all tthe new converts to Zymol Carbon, you can get it delivered from the US for $76 ($30 of that is shipping ), still cheaper than buying it in the UK I think...
    • CliveH
      • Jun 2005
      • 1319
      #32
      gotta link please...?
      Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
      Present: S4 B8 avant, MRC Stage 2
      • Coxy
        • Jun 2005
        • 1090
        Any one of those pictures could be on the Audifans calendar next year! Looks like Advertising shot material only with a better looking finish! Superb!!!
        • ericd
          • Nov 2003
          • 1240
          NCTS
          http://cgi.ebay.com/ebaymotors/Zymol...sspagenameZWD1
          I think they do the more expensive Z waxes also, still a good deal when you're buying in $'s though...
          • SR71
            • Apr 2004
            • 330
            I think I need to get a little educated on how to look after my paint....
            1 bucket and hose technique
            leather
            AG Super resin
            megs nxt
            Zymol Carbon
            Correct me if I am wrong, but S2DriverUK has applied 3 coats of polish/wax (Is there a difference?) to his car in this process?
            Autoglym SRP, followed by Meguiars NXT Tech Wax followed by the Zymol.
            Can one of the gurus explain why the car needs these three stages? Can it not just be Zymol'ed up after having been washed with, for arguments sake, Meguiars Gold Class Shampoo?
            I'd be tempted to remove the Gold class if you're attempting to put Zymol on top of it , the Zymol purists will tell you that you really need HDC for any of the Z waxes to bond, but I'm a bit of a heretic and it looks like others have sucessfully appllied it with out using the HDC.
            Presumably Eric is suggesting that applying multiple coats of polish/wax may result in hazing?
            What is HDC though? Some kind of pre-wax cleansing agent?
            How does one buff the Zymol carbon?
            Thanks.
            00 Audi B5 S4 MRC550
            08 RRS TDV6 HSE
            03 Kawasaki B2 ZX12R 1287cc
            • ericd
              • Nov 2003
              • 1240
              Thanks.
              applying multiple coats of different waxes usually causes varying results on a variety of cars, some people have their own 'regime/favourite' combinations of cleaner/sealant/glaze and wax, keeping things simple is usually my advice, sometimes you'll get people that go the acrylic way like myself, some even top the acrylic with wax (usually problematic, but everybody to their own)
              HDC (hd CLEANSE ) is as you suggest a pre-wax cleaner, zymol always suggest you use this as a base to any Z wax, for sealing/bonding/black-magic purposes, as many have proved you can use other paint cleaner and/or polish combinations before applying zymol or any other wax with virtually identical results.
              HTH
              • SR71
                • Apr 2004
                • 330
                Eric,
                Sorry to be a pedant...
                Are you using the term cleaner/sealant/glaze interchangeably?
                i.e., Are these individual stages in the "washing the car" process or does, for instance, Meguiars Gold Class shampoo perform all these stages in one?
                I've always thought there were only two essential stages to the "cleaning the car" process: 1) Clean it, 2) Polish/wax it.
                But I couldn't understand why S2DriverUK has used three polish/wax stages?
                Judging by the results, it is fantastic, but I want to make sure of the science behind the process he has used because I can't figure it out why three waxes are needed....
                08 RRS TDV6 HSE
                • ericd
                  • Nov 2003
                  • 1240
                  Eric,
                  David's used AG SRP (Autoglym super resin polish) as a paint cleaner it's got a little 'cut' in it and will remove oxidised paint and some small scartches etc, it will also add a little gloss/shine, so essentially it's been used for cleaning/glazing and finishing, the wax gives more depth and shine as well as sealing the finish that you've produced.
                  you can buy an All in One (AIO) from a few companies Klasse is one of the better known ones , this is renowned for being single step product which is applied and removed after initial washing, the finish is then sealed with a wax or sealant of your choice/s , P21S Concours works particualrly well on top of Klasse, I would say identical to the Carbon wax if prepped correctly.
                  One of the most important/beneficial/significant things you can do before any of the polishing/sealing steps is to clay the car, the removal of the 'invisible' contaminants on paint work by claying will have a significant effect on the final effect, you'll only really need to clay it once if you're doing it for the first time.
                  wash it (remove the visible stuff)
                  clay it (remove the rough and sticky stuff)
                  clean/polish it (feed the paint, remove dead paint and scratches)
                  seal it (protect your good work and the nice finish)
                  Others may argue there's more to it and we could have 7-10 intervening steps but these simple steps will transform the paint/finish on most cars without resorting to machine polishing etc...
                  get yourself a decent microfibre for buffing/removing any wax, lose yourself over at
                  www.detailingworld.co.uk for an hour or two , plenty good advice on products and examples of what's possible and with what.
                  • SR71
                    • Apr 2004
                    • 330
                    Cheers Eric.
                    I've been looking at that site and the polishedbliss.co.uk one.
                    If I have a new car (May 07), when should it first be clayed or is that a dumb question? The paintwork on it seems smooth as glass already - which I should hope having just paid a fortune for it.
                    Still I like that Zymol idea.
                    08 RRS TDV6 HSE
                    • T2Andy
                      • 1903
                      Ive always found porsche paint have the best feel and overall quality over everything else ,keeping a car garaged makes the most differance in keeping the car feeling and looking its best imo.
                      • Fat Audi 80
                        • 10547
                        Cheers Eric.
                        Generally you should not need to clay a new car. I have not clayed the last two customer cars that I did. One was a 3 month old A6 and the other a 12 month old BMW 5 series. If the paint is anything other than glass like however, the car will need claying. Really bad paint feels like sandpaper.
                        Eric has given a very good explanation of the various stages, and as suggested "detailingworld" is the place to be. However, be warned, once you open pandoras box it is hard to close again.
                        I have spend hundreds on detailing products including a PC and if you are anything like me you will keep striving for better and better results ad infinitum! That said, I thoroughly enjoy detailing my car and others and at weekends get paid to do something I really enjoy.
                        Cheers,
                        Steve.
                        The Perfectionist
                        • s2driveruk
                          • 12696
                          just to clarify......no science I used the SRP purely as I couldn't get any clay so figured it would cut a bit and prep the paint.....nxt cos, umm thought why not and the final step being the zymol cos i know it needed to be last on
                          The finish has remained superb!
                          1992 3b S2 Coupe
                          • Jas11n
                            • 5067
                            Where is me Zymol at the minute? Not heard of it's adventures for a while now.
                            2001 Avus Silver B5 RS4.
                            1995 S2 Coupe - sold (sniff)
                            • Fat Audi 80
                              • 10547
                              I was thinking that
                              The Perfectionist
                              • Paulgo
                                • Jan 2005
                                • 498
                                Originally posted by terrybullwon
                                David that looks fantastic
                                Perl white alway comes up tops (we all know its the best colour)
                                I have of course to second that!! Looks amazing - I must put more elbow grease into mine!! (Unless I can get Jas to do it again, as with most of the upkeep of me car! )
                                nice work!
                                Paul
                                Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
                                Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
