Any advise for removing surface scratches?
  • mcandmar
    • Apr 2004
    • 5118
    Two more q's to throw out there,
    What does PC stand for ...the first person to say personal computer gets a slap!
    And can somebody please explain the process of using clay bars, i don’t really understand how you "knead" the clay keep a clean side, and how often you need to do that. For example can somebody talk me though going over a bonnet with it, would you do a full stoke from windscreen to grill, and then knead the clay again?
    Cheers,
    Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • hiltoa
      • 1060
      • Home: United Nations Current: England
      PC = Porter Cable 7424
      Porter Cable is an American power tool brand, the 7424 is a popular Dual-Action polisher... This link will tell all you need to know...
      Nothing feels fast for long...
      2000 Audi RS4 - Kingfisher Blue ~+~ 2004 Audi Allroad 2.5 Tdi - Ebony Black Pearl
      • Ski
        • 2591
        I would also like to know the answer to marks question regarding clay bars.
        ABY Coupe
        • Sonic
          • Jul 2006
          • 5514
          Using a clay bar is pretty straight forward. If you've never used or seen one before its pretty much just a soft block of clay.
          To use it, make you you spray a load of lubricant over the paintwork you are about to clay. Put the bar in your hand and slide it across, or up and down the paintwork. Repeat several times.
          You my hear what sounds like a metallic scratching sound whilst sliding the clay, providing you've applied the lube this is just the bits of metallic rubbish that are embedded in your paintwork being removed by the clay. You will also notice loads of bits of "dirt" smeared in the clay at this point. This is the stuff your removing from the paint. The idea then is to knead the clay until you get a fresher clay surface to use again, so you don't end up scratching your paint with the dirt you've removed.
          Just make sure you always have a good coating of lubricant on the paint work!
          S2Forum.com Administrator
          • Ski
            • 2591
            #20
            yes but what does "Knead" mean?
            ABY Coupe
            • Nuvo
              • Nov 2003
              • 3828
              #21
              "knead" means to fold in on itself, just like you would with dough when making bread for example.
              • Cullam3n
                • Aug 2007
                • 993
                • Home: United States Current: United Kingdom
                #22
                Also with claying, the clay should be rather soft. Usually I knead the clay around in my hand under hot water for a couple of minutes so it softens up.
                • Fat Audi 80
                  • 10547
                  Yep. All very good advice about claying there. I would also recommend that you are careful with it and don't press too hard. I tend to work my way over a panel with light pressure, probably just the weight of my hand, sliding it until it hits debris. Move it back and repeat. As the debris is cleared you can move on. Treat it like clearing a mine field and proceed slowly and gently until it feels like all the mines have gone.
                  When done correctly the panel should feel like a brand new piece of glass....
                  Cheers,
                  Steve.
                  The Perfectionist
                  • mcandmar
                    • Apr 2004
                    • 5118
                    Thanks guys. Still a bit unsure what kind of shape/size do you work the clay into? Infact any pics of somebody doing it, pictures speak lounder than words and all that.
                    Cheers,
                    Mark.
                    • Cullam3n
                      • Aug 2007
                      • 993
                      #25
                      As you start out you probably will make it the clay thick, but as you get more experience you can get it thinner and thinner and apply more pressure to get the most effectiveness.
                      You are making it harder than it is Mark! Just knead it around and then flatten it to what you think is comfortable for you to work with, spray some lube where you are going to be working (do one section at a time!) and go to town.
                      • Fat Audi 80
                        • 10547
                        Cheers,
                        Mark.
                        I would recommend 1/2 to a 1/3 of a bar if you use the Meguiars Smooth Surface kit. I then flatten it between my hands to about 6 - 8 mm thick and go from there. You will find that it thins as you use it. Then fold it in half or a quarter flatten back to 6 - 8 mm thick and go again....
                        You will be fine. There is not that much damage you can do with it unless you don't use enough lube (it sticks and bogs down horribly then) or press too hard...
                        Cheers,
                        Steve.
                        Alternatively, come and see me and I will clay and PC (Porter Cable random orbital) it for you!
                        The Perfectionist
                        • Ski
                          • 2591
                          #27
                          theres a picture here mark :
                          A product that has recently come to promenance in the world of detailing is Detailing Clay. In this thread I aim to write a general guide to what clay is, what its used for and some generic tips for how to get results from clay. :) I will focus on the use of clay for the removal of bonded...
                          ABY Coupe
                          • Cullam3n
                            • Aug 2007
                            • 993
                            #28
                            Another guide
                            Nice woman too!
                            • Fat Audi 80
                              • 10547
                              Nice links guys.
                              The Perfectionist
                              • Jas11n
                                • 5067
                                Wait till you see the pics I post on Saturday of the HUGE swirls and buffing trails/holograms I have to remove from my rear offside quarter panel
                                Feskin heavyhanded painters
                                Jas..
                                (oh....wheel arch respray)
                                2001 Avus Silver B5 RS4.
                                1995 S2 Coupe - sold (sniff)
