Yes I had to use the Intensive Menz over the whole car due to the hardness of Audi paint. It was also applied with a 4" cutting pad for the same reason. It cuts that bit more than a 6" pad. You need to watch the heat build up with smaller pads, especially on the plastic bumpers etc.
As for pressure, I would say firm pressure is required (10 - 20 kgs) approximately. You should be able to feel the PC working and not just gliding. Less pressure at the end for the last passes to finish off the product.
I use a slow cut technique where I move the PC at approximately 1cm per second (after I have done some quick passes to spread the product out.) From memory I did about two slow passes per panel then a quicker finishing pass on a slower speed.
Have a read on www.detailingworld.co.uk and go to the machine polishing section. There a number of very well written guides.
HTH
Cheers,
Steve.
HTH
Cheers,
Steve.
