i found the right side (drivers) it was the same as the side lights number 6 or 7 i cant member now but the left side (passengers) is no where in sight im suspecting a fuse has gone as i got brake light but no normal light but checked the bulb and its fine so its not that at fault which leads me to a fuse but for the love of god i cant find it and all the fuse's in the fuse box seem ok after pulling every single one out to check please help lol thanks
audi 80 left side rear light fuse where isit?
If fuses are OK and bulb is OK - then I bet its a kak contact in the rear cluster - clean em with a coarse sandpaper to remove any crusties or oxidisation.Paul Nugent
just been out there now with the volt meter check direct from the plug that goes into the back light there now power for the light but is for the brake and indicator i used the each of the car on the body to double check its not an earth cable problem which leaves me thinking its the fuse but nothing on the fuse cover says about one for the left side only for the right? help lolThe Power Of A DagDagComment
problem solved again after checking in the fuse box somehow im not sure how fuse 7 had been put in fuse 5?? and well no fuse in 7 hence why no back light only found out after check fuse box with volt meter well im gona look a right dull one here so hope all that read can have a good giggle at my expensense lol doh!!The Power Of A DagDagComment
D'oh
