Audi A4 speed warning bleep
  • simyboye
    • Nov 2007
    • 168
    Hi there,
    My A4 tdi has a 60mph warning bleep that comes on every time. Ive tried everything! Removing battery, reseting the speed warning button etc... Its driving me nuts!
    Any ideas?
  • s2_wot
    • Aug 2006
    • 2178
    the s6 has the same, it's activated / deactivated by pushing in the little adjuster that's used for setting the time on the clock. I activated mine by mistake yesterday while adjusting the time. Maybe some use to you...
    Shane
    • simyboye
      • Nov 2007
      • 168
      Thanks. I know that holding the dimmer knob down, you get a MPH with a line through it. It just wont stop beeping at me...
      • s2_wot
        • Aug 2006
        • 2178
        Could you set it at a very high speed, one that you don't frequently go faster than??
        No other ideas for you I'm afraid.
        Shane
        • simyboye
          • Nov 2007
          • 168
          My diesel slag flat out is about 90mph. Downhill... But for some reason it just bleeps at 60?!
          Thanks for your help anyway.
          • s2_wot
            • Aug 2006
            • 2178
            Vag-com must have the answer
            Shane
            • Acidburn
              • 13459
              as above the dimmer switch should sort it.
              And is that it for the a4? should do more than that? even my tdi will do 120+
