Timing adjustment via vagcom - Which version?
  • philj
    • Feb 2010
    • 377
    Checked the timing on vagcom and it was out after a belt change. Adjustment was easy enough, although getting it right on the graph is a bit hit and miss as I adjusted it the the first one which turned out to be "all 1z's" after that there are a few choices.
    80 1z 92-94
    80 1z 94- d.08
    80 1z 94- d.09
    Typically they are all different, so if its set right on one, its not quite right on the other.
    Car is the later one, so it should be one of the last 2, but how can I check which one?
  • ManiacuV6
    • Dec 2009
    • 458
    • Country: Romania
    Make a print screen when you enter in the engine diagnsotic and post it.
    Audi S4 2.2T 5 spd 1992 for parts
    AUDI A4 1.9TDI daily use
    Audi 80 Quattro 2.0 16V (ACE) aka Competition
    • philj
      • Feb 2010
      • 377
      • ManiacuV6
        • Dec 2009
        • 458
        • Country: Romania
        LAst one is the right choice .
        • philj
          • Feb 2010
          • 377
          Cheers! Obviously the first one is for the early cars with the large afm. For future reference, how do you know when you have the d.08 engine?
