Front subframe bushes
  • gunman
    • Jan 2009
    • 660
    Simple question for thems what knows, are the front subframe bushes the same across the range (aprt from the 10\12mm hole)? i.e. are the S2 bushes the same as an 80 tdi? I have a set of alloy bushes here for the S2 which I never fitted, the 80 is for mot in 3 weeks and the rear bushes on the front subframe are shot to hell (got an advisory last year). Will the alloy ones go in there?
    cheers.
    1996 Audi S6 Avant.
    1994 80 TDI - Daily Driver
  • mcandmar
    • Apr 2004
    • 5118
    I'm 90% sure they will fit, as you say depending on the year of the car it will probably have the M12 bolts. Should be easy to visually check before you cut the old ones out..
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • caterpillar
      • 2480
      the 12mm hole was from 92 (pre 91)... there ar 2 differnt rubber; but its the height.. if you use the alu ones, remember the steel and the alu dont like to be together ( ione) use new bolts in...
      • gunman
        • Jan 2009
        • 660
        Turns out they did fit, put them in this morning. Also did the gear linkage oil seal on the gearbox, changed a CV joint and I have a brake hose to replace after lunch.
        Once I drive it I'll let you know what I think of the bushes.
        1996 Audi S6 Avant.
        • gunman
          • Jan 2009
          • 660
          Ride seems fine now, steering is a lot more responsive and the car no longer pulls to one side on throttle\braking.
          The old bushes were in terrible order mind you.
          1996 Audi S6 Avant.
