A4 Tdi quattro
  • chiefmechanic
    • Mar 2008
    • 198
    A4 Tdi quattro
    I have an 1997 a4 1.9 Tdi quattro as a daily but it has lay down on me. I have traced the fault to the ecu. I have a spare but the ecu is looking for the key code and the dash code. I cannot change these as the old lock is broken and the dash has different plugs. Does anyone know where I can get the immobiliser coded out for a small fee. The car is not worth much but is useful.
  • Monkeymagic
    • Mar 2012
    • 3419
    Id get a mobile locksmith out they should be able to obtain the pin nimber
    • chiefmechanic
      • Mar 2008
      • 198
      Negotiating another ecu with immobiliser removed. What do you mean by PIN number.
      • Monkeymagic
        • Mar 2012
        • 3419
        I have some literature on immobs somewhere. From memory you need to know your 4 digit immob pin to enter via vcds.
        • chiefmechanic
          • Mar 2008
          • 198
          Would be very interested to know about that. Can I access it using vcds. I have changed the abs module code with vcds. I expect this would be similar. Brian
          • Monkeymagic
            • Mar 2012
            • 3419
            The abs module will be changing soft coding. My understanding is that immob can be done with vcds once you have the code.
            • chiefmechanic
              • Mar 2008
              • 198
              Can I use vcds to get the code.
              • Monkeymagic
                • Mar 2012
                • 3419
                No sadly not. Although I understand why Ross tech don't allow such a function. I had this recently when I needed a key for my b5 rs4. In the end after a bit of haggling with Audi they cut the key supplied the fob and coded it to suit the immob for about £20 more than I could buy a key get a mobile locksmith etc. If you look on Ross tech website it will help you find the type of immob you have and offer advice.
