Feeler - Alloy Subframe bushes GB
  • Big Lee M
    • 2571
    I would be very interested in these for my Avant (at the right price) Front and rear.
    Just some finishing touches to do now
    • TideRS
      • Dec 2005
      • 61
      I would buy a set of avant rear bushings, the big ones, if you can get them made.
      • lind4hl
        • Jul 2008
        • 2465
        what is happening here? is there no shop in the whole world that are making the big ones in alu, im needing them now
        • s2driveruk
          • 12696
          i'll chase the company as I sent an email with details for a quote but nothing back just yet. If you need them now then Dialynx have them on the shelf...
          1992 3b S2 Coupe
          • TideRS
            • Dec 2005
            • 61
            #20
            No they don't, Dialynx only had S2 coupe bushes on the shelf when I asked. RS2 and other B4 sedans and avants has completely different bushes at the rear than S2 coupe.
            • martinjs
              • 3205
              I never knew that? can you post a pic? Did Ben make some when he made all the others a while back? I may be able to get some made?
              • s2driveruk
                • 12696
                i've got the samples from Ben to get this batch up...if you can do it Martin then i'll get them over to you
                1992 3b S2 Coupe
                  :mischeif:
                  • MidnightBlueS2
                    • Jul 2005
                    • 1653
                    • Home: United States Current: Belgium
                    #24
                    Me too !
                    Midnight Blue S2 - SOLD - 1993 S2 Avant
                    • lind4hl
                      • Jul 2008
                      • 2465
                      i have now contacted 034motorsport and i linked this thread, so maybe he is going to start fabricate them
                      so i will write here when something new happens.
                        Maybe we could get discount on 034 ones. They do offset front mods for more castor, which is nice
                        David, you planning on getting some offset ones made up for the weiss track cars?
                          I'd be interested in offset ones too :mischeif:
                          • s2driveruk
                            • 12696
                            Hadn't planned them no but i guess no harm in asking....what effect does increasing castor have on the top mount/bearing as it would take load at an angle right?
                            1992 3b S2 Coupe
                            • Azman
                              • 3205
                              Interested In avant fronts if them de right price dude
                              Az
                              Dark Grey Avant
                              RS2 FARB
                              Alloy Subframe Bushes
                                10mm offset changes the angle by about 1 degree so it's a pretty minimal change up top. 034 offer twin drilled versions with say 5mm and 10mm offsets. They have a pin hole that holds the bush in the correct orientation so they're not quite so straight forward. Be good to have a look as they would improve front cornering grip...
