Who has a peeling speedo face?
    Do they fit the 16v, speed and tacho the same? Can get more sets if there's a requirement, perhaps you'd like to organise a group buy? If you do want a few sets then please get in touch. Will look into other websites when I get 5 mins free.
    • andy10v
      • 5996
      Should fit the same, redline will differ depending on the car, 16v and 10v are about 6200 compared to the s2/20vs 7000, sholdnt be much of an issue, other thing would be temperature graduations,
      Iv gotgot 10v, 16v and s2 sets in the garage so will have a look.
      Sold ABY-stock
      • bikerjim
        • Feb 2008
        • 1028
        Have a good look andy, i just had a look at a pic of my speedo and it seems they do go to 160 but the ones in the pics on page 2 look like the speedo goes to 160 and a little further.
        By the way with the plasma ones in the aux guages how do you fit them, arnt they sealed units? or am i going
          Ok, cheers guys No auxiliary gauges in this batch but can get them sorted if there is a firm order and someone provides a sample, black or white. Might get my VDO boost gauge sorted then too. No idea on plasma fitting, search for Bo's fitting threads.
          • andy10v
            • 5996
            Forgot about that, some of the clocks are 140, some are 160, will try and get a pick of all three tomorrow.
            Sold ABY-stock
              I can get other versions sorted if there is a firm order for say 10 sets.
              • andy10v
                • 5996
                s2 clocks-3b
                16v-6a??
                10v-ps
                And taken from audifans here
                The engine codes ABT and ABK had speedo's up to 120mph
                The engine codes ACE, NG, NM, ABC, AAH, 7A got speedo's up to 160mph
                The engine codes ABY, 3B got speedo's up to 180mph (280kph) & 200mph (320kph- the rs2)
                This all I noticed in B4 models
                and
                The UK S2s only got 160mph speedo displays.
                Hope that helps.
                Sold ABY-stock
                  Thanks for that. Only the speedos look a little different for all 3 although the 160 and 160+ are very close. I can get a quote for small batches if there's a market, will need the speedometer faces to compare.
                    If I can get tacho and speedo dials from the 120+ and the 160 speedos then I can get them looked at.
                    I am also going to ask about turbo gauge faces in the correct illumination and font.
                      I've got a black 160mph speedo and 7k tacho you can have mate, but they have been cut in half. any use?
                        Enough ones in good condition I hope... thanks for the offer, wait and see...
                        • rotoryboy
                          • May 2004
                          • 3281
                          Hi Andy, Where are we upto with these?
                          Mark
                          Race Clio RS197
                          S2 Coupe ABY (Green) - RIP
                          S2 Coupe ABY (Blue) - Sold
                            The company are working on the design, need to get it right as they won't do samples
                            • rotoryboy
                              • May 2004
                              • 3281
                              Yikes, fingers crossed
                              Mark
                              Race Clio RS197
                              • rotoryboy
                                • May 2004
                                • 3281
                                Are we any closer with these? Did you manage to sort the 'Lighting' out?
                                Mark
                                Race Clio RS197
