ABY, ADU flywheel lightweight version poll
  • Tommy200rs
    • 285
    Hi,
    Target is to build a version where original ABY,ADU clutch can be mounted or the sachs race engineering pressureplate with original clutch plate or harder one.
    The reson for using original dimensions is that the race pressure plate... 724 for ABY or ADU offers better NM capability than the harder to use 3B pressure plate ....707. Also the 724 is lighter to use, which is huge benefit in stop and go traffic.
    Weight target is 7 to 8 kilograms.
    I´ll make the evo version available to forum readers if there is some interest ?
    tommy200 ----@---- jippii.fi
    ps. note that the package needs full rebalancing.
    tommy, spotted this on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.d...513316443&rd=1
    • Tommy200rs
      • 285
      Slightly missed the bidding of that heavy weight ugly ABY ADU monster flywheel. I have checked the delivery time of leightweight flywheel manufacturing and that is approximately 3 weeks from order, but the master model is still missing.
      here a picture where the diference for pressure plate mounting can be seen in ABY, ADU:
      • Tommy200rs
        • 285
        I´ll get tomorrow one heavy ADU flywheel for delivering it directly to CNC shop for making a light one. If someone interested in having equal, I can take group orders in for this batch.. Price will be very competetive compared to spare part price. Email directly me for details. Estimated delivery time in january (2 to 3 weeks).
        This Blue S2 allready has the ultralight version flywheel.
        It spins up to 9500 RPM:
        Sachs clutches:
        ZF Race Engineering envisions leading the transformation in future mobility solutions, seamlesly blending our heritage in motorsport, motorbike and high performance street products with cutting-edge software and systems.
        I prefer the ...724 pressure plate and therefore wouldn´t use the 3B flywheel and ..707 for ABY/ADU. 724 also offers better NM capability.
          Tommy, guess you are already aware that there are two different ABY/ADU?AAN flywheels
          • audiman
            • 4827
            Im not 100% sure that here are 2 different ABY/ADU flywheels. I think that the AAN is different to the ABY/ADU. Can anyone confirm this. I have only come across one different flywheel. We need more ppl's experience.
            Tom C - www.rcmr.co.uk
            Audi UR Quattro
            Audi 100 C3 2.0 5 cyl 115ps
            Audi B5 RS4 645ps 911nm
              Well when we had a look a while back with lee and doug one type is like the one tommy took a picture of and the other has an extra ring on the pressure side around the edge which is about 15-20mm wide and the same high protruding from it.
              The AAN flywheel that I got from the short block i used on mine was the same as my current flywheel also, lee has got my old one now.
              • Tommy200rs
                • 285
                Flywheel approximate weights
                3B 200 ~8. (have it)
                3B S2 - havent measured/seen
                AAN ~11. (have it)
                ABY,ADU ~14. (have borrowed it)
                Price will be for light ABY/ADU version ~600eur + post
                • audiman
                  • 4827
                  So i guess i was right about the flywheels then??
                  Is the S2 3B and 200 flyhells the same???
                  Audi UR Quattro
                  • Tommy200rs
                    • 285
                    - interesting question and I would like to know the difference too
                    - The light weight wheel will be ready this week
                    - another ultra light 3B available 6,5 kg.
                    - Lower is not recommended for street
                    AAN original clutch plate does not have the torsion springs at all
                    ABY ADU plate does have the springs but the LUK stock variant has some damned plastic toy material in the plate. I´ll check how the sachs stock plate variant looks like. probably no plastic ?
                    • AnLe
                      • Dec 2003
                      • 291
                      - interesting question and I would like to know that too
                      This is the 1001 time that I say to you IT IS NOT THE SAME damn it.
                      • Tommy200rs
                        • 285
                        show the #1001 picture of the "flyhells" ?
                        • audiman
                          • 4827
                          Just done some research on part numbers for you Tommy
                          200 IS different to S2 3B
                          200 is 034 105 270S
                          S2 3B is 034 105 270AA
                          ABY/ADU is 034 105 266E
                          AAN is 034 105 266C
                          Audi UR Quattro
                          • AnLe
                            • Dec 2003
                            • 291
                            I dont have any 3bs2 to take a picture, but if you dont believe me or the other,
                            it is your loss, check etka for instance, they have picture and different part number.
                            • Mihnea
                              • 1288
                              This is correct, the S2 3B and 200q20v 3B flywheels ARE different. BTDT!!!!
                              www.MRCTuning.com
                              info@MRCTuning.com
                              Workshop Directions
