RS2 water pump pulley group buy
  • terrybullwon
    • Mar 2006
    • 8782
    I have now had the sample drawn up.
    Looks like there a few options and before I make a set design up I thought I'd test the water.
    Right. These can be made in aluminum or steel. Price is pretty much the same both ways, other options include anodizing in maybe something like back or silver. Brighter colours on request.
    Do people want them pressed onto a new pump or just a item they can swap them selfs?
    Price wise £60-100 depending how many I need to take.
    Who's interested
    Chef
  • Kryptonite
    • Aug 2010
    • 63
    im interested! for me it would be the best, if i could swap the pulley myself.
    (material: do you know the material of the original pulley?)
    • Henkjan
      • 1705
      interested...
      would prefer it pressed on a new pump, but the thing alone is no prob
      • vti2
        • Jul 2010
        • 281
        • Home: Portugal Current: Germany
        Interested
        • inne3quattro
          • Oct 2009
          • 55
          I'd take one, would prefer aluminium
          • dhali7376
            • Nov 2009
            • 301
            Put me down too
              I'll take one mate. Loose to press on as required would be best for me. I vote for steel if poss
              • SteveH
                • 4460
                Is the shaft diameter the same on 3B and ABY/ADU pumps? If so, I'd take one to fit to a 3B pump.
                91 Modded 3B
                14 A6 Avant Black Edition
                  Won't you need to also have a GB on the RS2 150 teeth toothed cam belt too?
                  RS2 = 034109119C = 150 teeth according to the photo
                  Cam belt and water pump pulley info: http://forums.quattroworld.com/s4s6/msgs/131710.phtml
                  • rxl
                    • 1913
                    my rs2 had the 151 version of the belt and it worked fine in combination with the rs2 water pump
                    • Quattro Dan.
                      • Dec 2005
                      • 746
                      I could be wrong but you may get a problem with dissimilar metal corrosion if you use an alloy pulley on a steel shaft? Obviously anodizing should avoid this, just avoid leaving it bare alloy.
                      Good to see someone addressing the NLA and extortionate heritage prices.
                      • pasbogdan
                        • Sep 2009
                        • 1160
                        • Country: Romania
                        What difference of ID/bore will be between aluminum and steel part?
                        Regards,
                        • mac2226
                          • Jun 2008
                          • 1289
                          I'll be interested in one
                          • SteveH
                            • 4460
                            Dave,
                            Do you have any details on the right belt to use on a 3B with and ABY head and cam wheel?
                            91 Modded 3B
                            • pasbogdan
                              • Sep 2009
                              • 1160
                              • Country: Romania
                              If my "imagination" works at this moment using adu wp with any(except adu) i5 20vt cams/sprocket and any belt length(that will tension ok)will get timing half tooth to the left.Because wp sprocket diameter dictates camshaft timing.Not the belt length.
