Group Buy: 5x112 HUBS
  • Nimz
    • Sep 2011
    • 309
    Hi guys,
    I've managed to find an engineer who can make the S2 5x112 hubs; these can then be pressed in to 4 stud typ89 legs. As we all know the S2 hub assemblies are getting harder and more expensive to get hold of these days! This solution can be purchased for £200 per pair. If there is enough interest I will press go on the manufacture. Please start a list below, stating whether you require fronts, rears or a full set of 4. Once there is enough preliminary orders I shall contact you for a deposit. Cheers.
    1. Carlin = fronts
    2. Tonks4x4 = set of 4
    Nimz - White S2
  • Andrew Conway
    • 23
    Hi Nimz
    With not know the difference in legs would these hubs push into UR Quattro legs/bearings?
    Andrew
    • dwalmop
      • Nov 2009
      • 13
      I would be interested in fronts!
      • Nimz
        • Sep 2011
        • 309
        UR quattro legs are already 5 stud. But I don't think these will fit
        Nimz - White S2
        • Nimz
          • Sep 2011
          • 309
          Add your name to the list dwalmop
          Nimz - White S2
          • terrybullwon
            • Mar 2006
            • 8782
            Would they do a aluminum version?
            Chef
            • rs2coupe
              • Oct 2004
              • 1782
              • Home: Trinidad and Tobago Current: United States
              ^this and any change in et+ or - ?
              Cheers mis amigos,
              _Anton
              • Nimz
                • Sep 2011
                • 309
                At the moment we are just looking at standard "like for like" however if there's a large enough demand for something different then we could possibly look at making some changes. Although a bespoke spec for each person is not a viable option, they have to be done in batches.
                Nimz - White S2
                  What material?
                  • Spillies
                    • Aug 2010
                    • 66
                    Can I replace my 4x108 B4 Competition hubs with those 5x112 S2 hubs?
                    Do you perhaps have an example photo?
                    • GazzaG60
                      • 4133
                      you need a bigger bearing for the 4x108 to 5x112
                      get a set of v6 carriers then they will work
                      • Wizard-of-OD
                        • 926
                        • Home: Syria Current: Canada
                        why are people not machining URS4 hubs?
                        Issam N. Abed
                        iABED Industries
                        iABED Email | Facebook
                        The build thread
                        • _ShurikeN
                          • Mar 2010
                          • 733
                          • Country: Russian Federation
                          They do. My budget for hubs for CQ was 50USD with some sort of luck.
                          • andy10v
                            • 5996
                            What hub bearing and what cv/axle size are you making these for?
                            Sold ABY-stock
