1.8t Coil Pack DIY Conversion Connector Update
    Markus Fagervik of Finland has found the allusive 4 pin Volvo/Bosch connector that takes the place of the male POS connector and mates with the four pin ECU connectors in the 1.8t coilpack conversion.
    The Part No.s are:
    Bosch: 1 928 402 373
    Volvo: 978161 30854061 (according to the photo)
    Photo is at:
    http://forums.audiworld.com/s4s6/msgs/123810.phtml
    The conversion DIY instructions (that I wrote) are at:
    http://www.s-cars.org/postnuke/modul...rder=0&thold=0
    Hope this helps somebody.
    Dave F.
    PS: Mike Hayes came out for one of our Vancouver BC Canada UrS4/S6 meetings. He seems to be adjusting not to badly to driving on the "wrong" side of the road.
    Even more Volvo PNs for the DIY 1.8t coil pack conversion
    "Rudack" on Audi World offered even more Volvo part numbers for the DIY 1.8t coil pack conversion:
    The following parts to go with the 4-pin Volvo POS connector (PN 978161)
    Loose male terminals: 978299
    Cable Seals: 970773
    HTH
    Dave F.
      Ive posted the PDF of your guide
      • s2dude
        • Nov 2005
        • 1631
        Does this work fine for a 3b conversion then??
          Good question, it really depends if the coil leads are long enough to go through the cam cover & you will also need a way to trigger the POS
