7A no start after valve cover gasket replacement
  • cgharibo
    • Aug 2011
    • 165
    Happy new year,
    I changed the valve cover gasket on my 7A. I removed the airbox, and just flipped the IM to the side to change the valve cover gasket.
    everything went fine seems connected but the car cranks and does not start. There are no codes.
    what did I do?
    Thank you.
    • Dec 2017
    • 5983
    You have probably knocked a connection off or left something undone. Hall sender plug on dizzy a good place to start.
    • LSG
      • May 2010
      • 897
      Air box not sat down properly ?
      • cgharibo
        • Aug 2011
        • 165
        It ended up being a loose connection to the coil.
        Thank you!!
        • LSG
          • May 2010
          • 897
          Pleased you sorted it out fella
