7A chain behind timing belt seems loose
  • cgharibo
    • Aug 2011
    • 165
    I recently replaced the valve cover gasket on my 7A and noticed the chain behind timing belt under the valve cover is slightly loose.
    Is this normal? How taut should this chain be? How do I tighten it?
    Thank you.
    • Dec 2017
    • 5992
    A small amount of slack is normal, especially in high mileage car. Change it next timing belt change. The chain is cheap to buy as was fitted on other vag group cars.
    • cgharibo
      • Aug 2011
      • 165
      Is it called the timing chain?
        • Dec 2017
        • 5992
        Camshaft timing chain
        077 109 120
