1991 Audi 7A Cutting Out During Acceleration
  • cgharibo
    • Aug 2011
    • 165
    Hi there,
    I have a 1991 7A CQ with 320,000 miles. Last few months, the engine has been cutting out during acceleration and even when the car is throttled in neutral.
    It never stalls but you can sense the power delivery is interrupted for microseconds repeatedly.
    I changed the coil without improvement. There are no codes.
    What are your thoughts?
    Thank you in advance.
    CG
  • John.
    • 2615
    Are you thinking it's an interruption on the low tension side of the ignition ?......... A failing king lead would have a similar effect. That would be an easy fix ! Have you checked the condition of the king lead at the cap?
    Weather on the original Hitachi injectors or aftermarket it'd be worth checking the connections under the scuttle ?
    Ignition switch issue ?
    Worth going through all the connectors and checking the condition.
    Great engines the 7A's, 320k is proof
    • PeterS
      • 423
      Chris: check the condition of the connector to the temp sensor on the rear of the head near the battery. I've had two CQs with broken connectors giving intermittent contact and like performance issues that you are experiencing.
      Peter S
      1990 ErsatzS2 - track toy
      1991 Coupe Quattro
      1991 Coupe Quattro
      1995 S6 Sedan
      1995 S6 Wagon
      • K Simmonds
        • Dec 2007
        • 7627
        As a rule missing or cutting out under load is an ignition problem, normally on the HT side but not always, how old are your ignition leads and dissy cap?
        Both the guys above have given you a good advice so you have a couple of things to check out.
        Assuming all is well with those electrics then the next thing to check is the fuel filter and pump, however dying pumps are normally noisy and I doubt this is the issue.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • cgharibo
          • Aug 2011
          • 165
          Yup, will check this weekend! Thank you, everyone. This is the best vintage online Audi group out there.
