1991 Audi Coupe with 7A motor - 360,000 mile service finding
  • cgharibo
    • Aug 2011
    • 165
    I am in the midst of doing 60k mile service on my 1991 coupe with the 7A engine. The car runs like always, slow but good and does not burn oil.
    I took the plugs out to change and they all look great. I put a scope in the plug holes and I can clearly see black carbon deposits on all the pistons.
    So how do I get rid of these carbon deposits on the piston head or do I just leave them? The newer Audis that burn a ton of oil are subjected to Berryman B12 piston soak where the solution is left in for like 24 hrs. Should I do same piston soak, do something different or just let it be and put new plugs in there and move on.
    Thank you!
  • K Simmonds
    • Dec 2007
    • 7627
    If it's running fine as indicated by the colour of the spark plugs I'd be inclined to leave the contents of the cylinders well alone, a light coating of carbon on the piston crowns is completely normal with a naturally aspirated engine and not an issue.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • Bowie69
      • Nov 2013
      • 2675
      Yup, leave them.
