1995 Audi 90 V6 12V Heating Core doesnt heat up
  • cgharibo
    • Aug 2011
    • 167
    Hi!
    I just replaced a 1995 Audi 90 V6 12V Heating Core and only have heat with RPMs above 2500.
    Initially I though it was a blocked heater core but it is not. Two separate heater cores are both not heating the cabin at idle.
    What's keeping the heater not working well at idle and how do I fix it?
    Thank you!
  • PeterS
    • 426
    likely trapped air...did you use a vacuum-coolant filler like an airlift or just pour in new coolant?
    Try raising the front of the car (alot) to see if the system will bleed for you with the engine running.
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
    • Alburglar
      • Oct 2017
      • 59
      Yeah needs bleeding. IIRC I did as above and raised the front up and with cap open. Throttled on and off until it burped a few times and level dropped. Filled it back up and working ok then at some point whilst driving, over the next day or so, the level dropped again, so must be a bit of tricky one to get all the air out, first go.
      • Alburglar
        • Oct 2017
        • 59
        ...Two separate cores? One will be heat and one air con.
        ..oh I see what you mean, you've had two separate cores on it...
