Bought an original C5 A6 Aero Twin kit on ebay.de Came to 40 euros+P&P
Plug & Play, but passenger side blade needs replacement with 20'' instead of 22''
Nice! But I wonder... I notice that Skull23 and Kaala have fitted them differently. Skull has the "bent" one on the passenger side and KAala has it on the driverside. Both setups looks über but I think that Kaalas is the nicest one. But on that setup the wiper would go down over the trim that surrounds the windscreen. That can not be good in the long term? Skull23, does your arm on the passenger side go over the trim?
/NEO - I have a sexual thing for big brakes. www.irry.com | Irry got a face lift!
#nordicaudi @ irc.nordicaudi.com
^yes my passenger blade goes about 2 inches over the edge, and I'm going to replace the blade with one that is a bit shorter. These bosh blades come pretty chep off ebay these days....at least compared to norway, where a set of aero twin blades cost £90,- at the dealers.
Mine were labeled "bent arm for driver side, and straight arm passenger side", On Skulls setup there is a large unwiped area at the bottom right, but it doesn't look to be any significant difference.
The unwiped area bottom right on that pic is not important, if you will take a shorter blade, u will reduce the wiped area infront of the passenger. that reduces your sight too.
