Hi there,
I came across your thread regarding the ambient temp display in the Audi clusters/clocks. Hoping you can help me.
My car is a US spec car. the cluster that came with it did not have the ambient temp display. The car did have a 5 pin connector prewired to the car, but it was not connected to anything. It also only had 4 wires pined to the connector.
I bought an S2 cluster that had the ambient temp display. I connected my car's factory connector to the cluster/clock's ambient display connector. The display worked fine.
I then swapped the ambient display to my factory cluster/clock and the ambient display display does not work. Any ideas?
Regards
Khai
Ambient temperature display, complete retrofit.
This is a sticky topic.
I’m going to revive this post.
Before reading this post on the Audi A40919272 external temperature gauge I was working in installing an LED as well. I now have one installed but in the process I pulled off a resistor and can't find it. Does anyone happen to have pictures of the back side of the board, the side opposite the LED, or happen to know the values of the resistors on the back side of the board? I didn't notice anywhere in the post about changing the current limiting resistor. Is this not necessary?Leave a comment:
ATD will not work without sensor. The sensor is mounted on a little metal bracket and sits in the space between the front of the radiator and behind the front bumper & cross member.
The sensor is shared with the later digital climate systems so if you've got one of those you'll have the sensor otherwise you'll need to fit a sensor to get the ATD to work.
JohnLeave a comment:
I know that this is the S2 forum but this is the best source for ATD
I got 1990 typ 44 avant with aftermarked ATD...
behind the clocks there is 5 pin yellow connector... after reading this topic I got the BORG ATD (4A0 919 272 C) from S2
checked the pins
seems ok1 = Vehicle Speed signal (2 wires 1 pin)
2 = Temperature sensor
3 = Earth
4 = Illumination (2 wires 1 pin)
5* = +12v
connected the ATD... ignition ON... Illumination ON... nothing
checked the PCB and its completely different from this
the brown wire (pin #4 = Illumination) seems to go nowhere...
and will ATD work without the sensor? not sure if I got the sensor connected somewhere... couldn't find it...
can get some photos if needed
i really want one of these units but i cant seem to find one second hand anywhere
Might be of interest, My 91 CQ20v had this VDO unit, 92 S2 dash i bought, and my 94 S2 both have the BORG units. Also noticed subtle differences within the two BORG units.Never seen this version before though. Only ever seen the BORG made units (part numbers beginning 4A0) which had a few revisions. Even on the last revision, I've seen four different PCB's inside.
This is an early unit made by VDO instead (part number beginning 893), it's still on it's original bulb inside too which is very different to the later ones. It's externally and internally very different from the BORG units.
Has an ink stamp on the yellow connector of 9/1991.
Not much difference in operation, though the VDO has better deflection for the bulb so it illuminates more evenly when you fit an LED.
If you want to know which you have turn the ignition on, VDO unit turns on instantly, BORG has a 2-3second delay.
I've attached pics of the two bulbs to compare the size..Leave a comment:
Just an info post.
Recently bought another of these ATD's (Thanks Andy
) as I want one in the work hack TDi.
"Borg" unit and the most commonly seen;
Early "VDO" unit;
Misc pics of both;
by CC you mean Climate Control?
in that case i misunderstood that. i thought you were talking about the ambient display
my TDI has no extras(not even air con), so i'm doing my best to retrofit them.
i would really appreciate any help, to change the ambient display back to C.
since my other car's temp display's PCB is completely different than the UK unit, i'm kind of stuck with reverse engineering.Leave a comment:
Zoig asked "explain how to change the readout from F to C?"....
On my CC head it is just a matter of sliding the button in the upper right corner over to the C° mark from the F°.
Do you have the OEM US only Delco CC head?
Hi,
panzerwagen, could you explain how to change the readout from F to C? i bought a UK temperature display, to retrofit to my other TDI, but when i tried it first in my Audi 80(with stock temp display), it only showed F.
when i compared the UK display mith my stock german one, their PCB was entirely different. you could really help me out with that
Hmmm I have that already on my CQ. Seems the Delco..
CC head unit has a temp readout on it. It can be switched from F° to C° by pushing a button.
