Fitting Powerflex Bushes
This is a sticky topic.
    replied
    is that the inner knurling you can see in Paul's pics i wonder?
  • Acidburn
    replied
    I spoke to martyn about these when I popped in and ordered mine (saw yours on the wayto you paul ) and they said that powerflex re-done them to get rid of the squeaking that the first versions had.
  • s2_bo
    replied
    Nice one Paul,
    Im sure people will find this write up useful.
  • Fat Audi 80
    replied
    Great info Paul
    Cheers,
    Steve.
  • A80Avant
    replied
    vagparts is cheaper than powerflex itself!! im going to buy them from there...
    replied
    Seriously - go to www.vagparts.com - you will find what you need. RS2 FARB joints are PFF3-103-27 !
  • s2driveruk
    replied
    i reckon on standard subframe mounts these will be a winner, with alloy mounts and these you might be getting more noise through them. I have the ally mounts and oem w/bone bushes, if they fail soon then I'm going this way too....the car is going to be tracked more this year and is definately a 3rd car now so it can afford to be trading some comfort for feel/performance i think
    Keep us posted...
    David
    replied
    I got mine from VAGparts - PFF3-102 !
    Oh and they seem to have a mighty list of Powerflex bushes for RS2 and S2 Avant - looks like all them at 1st glance.
    Paul
  • A80Avant
    replied
    are the front ARB bushes a worth while replacement with powerflex?
    Also which is the correct part for the RS2?I dont remember which width is the FARB!
    thanks
  • A80Avant
    replied
    which wishbone are those paul?i have the same so what part number for those wishbones from powerflex?
    replied
    And finally - just a snap for reference of the correct orientation of wishbone bolts. Torque setting on these is 40Nm plus 180 degrees. Not easy to do on the ground...
    Paul
    UPDATE - I have just realised the attached pic is labelled wrongly. This wishbone is actually from the opposite side and therefore FRONT and REAR should be swapped over as well. Sorry for any confusion - will try to dig up original pic and rectify labels.
    replied
    Number 5... With pins inserted and notes about why they need to be centred - the supplied washers just fit on the ends and some grease is required to hold them there while handling them and fitment.
    replied
    4th one up - inserting the metal pins. Photo shows wrong side - you soon realise this as it pushes the rubber out the fat-end. D'oh - didn't take a pic from the right way round. Tap -em in from the outside !
    replied
    3rd pic - Rubber bits installed with copius grease. Notes added to pic.
    replied
    2nd of 6 in this lil montage... Contents of the Powerflex bush kit.
