wrist pin removal/big end bearing fitting help please..
  • avants2turbo
    • Feb 2008
    • 1287
    need some advice,
    Im removing the wrist pins from a set of pistons and rods, there out of the engine, whats the best way to do take the pins out without damaging anything? Secondly, fitting big ends bearings, whats the best way, order, do i oil them up between the shell and rod or keep dry? Do i oil up between the shell and crank? Torque settings, how do i avoid spinning the bearings?
    General tips and hints wanted please...
    Thanks
  • mcandmar
    • Apr 2004
    • 5118
    Wrist pin clips have two holes for removal, you use one of those special pliers (dont know the name for them) or any pair with a long fine nose on them.
    As for assembly i would recomend assembly lube as engine oil will only drain away after a few days.
    I would put a lite smear of oil between the shell and rod/block to stop them rusting while sitting, but little enough that it wont get compressed out when torqueing up the caps.
    They wont spin in there caps as they have locking tabs to stop that, if they did they would block up the oil feed from the block.
    Dont know the torque settings off hand, i'm sure somebody here will have a note of them to hand.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
      circlip pliers
      • volcano rs
        • Jun 2005
        • 2265
        are you mad ? using oil between block and shell bearings will cause it to spin the bearing .it has to be totally clean .
        • mcandmar
          • Apr 2004
          • 5118
          Thin film of oil won't make any difference, there held in place by the keyways not friction. Besides they have oilways drilled through them with 5bar oil pressure, there is always going to be A film of oil there.
            and the bearing crush will also help keep them in place, but i've never read anything about oiling the tunnels
            • Kieron20V
              • Mar 2008
              • 1505
              You'll need circlip pliers as said above to remove the wrist pins. If they dont push out with a moderate tapping, then heat the piston up a little, not too much, just enough for it to expand and loosen the grip, try not to heat the pin up.
              You should really use new bolts for the mains, and new nuts on the big ends.
              I dont have my book here with me at the mo, its in my car at work so I cant put up the torques, someone will have them, try motorgeek.
              Kieron.
              1994 URS4 Avant RS2+
              • avants2turbo
                • Feb 2008
                • 1287
                but what about actually removing the pin, should i clamp the piston in soft jaws and tap it out with a mallet and drift, or a press?
                • avants2turbo
                  • Feb 2008
                  • 1287
                  Kieron.
                  Im not touching the mains, just the big ends, seems that one of the small ends has been chewed up, so im using the rods and pins from the other engine ive got, and using the pistons from my engine, and replacing the shells because i have just bought new rs2 ones from the stealers..
                    given what happened to the engine I'd check EVERYTHING mate
                    • Knight Rider S4
                      • 3541
                      Thought I would find some vids for you as youtube/ 5min.com is a great way of understanding the process rather than just reading what to do ..Happy viewing
                      Gudgeon pin install http://www.youtube.com/watch?v=H2YrL...e=channel_page
                      Engine Bearings http://www.5min.com/Video/Engine-Bea...tions-39414874
                      93 S2 Avant Parting
                      91 URQ RR
                      02 A4 tdi Avant
                      • GazzaG60
                        • 4133
                        remove one clip and push the pin out. use a socket thats the same size if need be and give them a tap.
                        should come out easily.
                        • avants2turbo
                          • Feb 2008
                          • 1287
                          anyone with torque settings for the rod caps?
                          • Knight Rider S4
                            • 3541
                            What rods are you using?
                            93 S2 Avant Parting
                            91 URQ RR
                            02 A4 tdi Avant
                            • avants2turbo
                              • Feb 2008
                              • 1287
                              standard ABY rods
